Hi I have problem with my Canon CLC 1150. When turn on, starts boot up process, then stops showing E804 - 0006 error cod. I found the error code shows that the power supply fan is broke. I checked I think 9 fans, and they are all working fine. None of them is near the power supply, so maybe there is one more that I couldn't find. Can somebody tell me where is located the power supply fan (FM6) in the machine? Or there is something else I should check??? Thanks in advance
• The operation of a fan (indicated by detail code) is faulty. • The CPU PCB is faulty. • The DC driver PCB is faulty.
0001 The electrical unit fan (FM8) has stopped to rotate in error. 0002 The IP cooling fan (FM7) has stopped to rotate in error. 0003 The exhaust fan (FM2) has stopped to rotate in error. 0004 The ozone suction fan (FM5) has stopped to rotate in error. 0005 The toner suction fan (FM6) has stopped to rotate in error. 0006 The laser scanner motor cooling fan (FM4) has stopped to rotate in error. 0008 The primary charging assembly fan (FM3) has stopped to rotate in error.
E804 0006 The laser scanner motor
There is no 000B in the manual....so I assumed it was a six.
The sub codes possible are 0001, 0002, 0003, 0004, 0005, 0006, 0007 and 0008. They all pertain to cooling fan failures.
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
http://www.canon.fr/ Go to this location and see if they have a posting for manuals in french. You also may be able to purchase through ebay UK. Canon's help number is 1800okcanon they might be able to assist you as well.
