Lexmark printer z600 it is connect correctly, it will not print documents it goes straight to print to files box but not printing
  • jrh21 May 28, 2008
    my printer is actually a lexmark 5400. it will not print. it is connected thru USB port and is connected properly. the power button will not light up though! it is all plugged in and i have restarted my computer. i have also tried two different outlets in case the one outlet, which it's always been connected to, is bad for some reason. what can i do??
    President:
  • 2,712 Answers
Open printer properties and uncheck "print to file"
Posted on May 19, 2008
I do not have a disk and cant install printer
Please visit the Lexmark website to download and install the Lexmark Z600 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation. Then try to print a document to verify that the driver is installed properly.
Dec 30, 2011 | Lexmark Z600 InkJet Printer
No disk install with out
Lost disk can i install with out it
I am trying to print and nothing comes out on paper. cartridge black half full and color full and it will not print anything from an open document to a new document with some typing on it. lexmark z600...
Try to clean the print cartridge nozzles. On your computer, go to Start menu > All Programs / Programs > Lexmark Z600 Series > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a clean test page forcing ink through the cartridge nozzles and clean them. Try to print your document again and to check if print quality is achieved.
Jul 25, 2011 | Lexmark Z600 InkJet Printer
Is there any way to get Lexmark z600 working on win7? OS recognizes the printer but when one actually tries to print the printer goes offline. Are there any suitable drivers for my OS or I'll just have to...
There is no Lexmark Z600 driver specific for Windows 7, however, the Vista driver works. Check if your Windows 7 is running on 32-bit or 64-bit operating system by going to the Start menu > right click on Computer > Properties. Download the driver using this link: http://bit.ly/cd4MzI(for 32-bit) or this link: http://bit.ly/c4xCtN(for 64-bit). Execute the file to install the driver. If you need further assistance, you can also contact Lexmark technical support. Thank you for choosing Lexmark.
Sep 16, 2010 | Lexmark Z600 InkJet Printer
Page isnt prining out Have new ink in printer
Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
1. Print another PDF, such as the first page of Acrobat Help.
  • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
  • If the separate file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
  • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
  • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF.
  • If the file prints correctly, your system may have been out of memory or resources.
  • If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
  • If the file prints correctly, the printer's memory was too full or had become corrupt.
  • If the file still doesn't print correctly, go to step 5.
5. Print from another computer.
  • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
  • If the file still doesn't print correctly, go to step 6.
6. Print a PDF to another printer.
  • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
  • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Lexmark Z611 InkJet Photo Printer
Lexmark Z600 printer
u have to change your printer port
go to settings control panel printer then its properties
then go to port check mark on usb port rmeove check form print to file youur problem is solved
Sep 13, 2008 | Lexmark Z600 InkJet Printer
Unable to print
sounds like a dogy usb cable try a nother usb cable before you give up
Feb 07, 2008 | Lexmark Z600 InkJet Printer
Lexmark z600 will not print documant
Sounds like the install was corrupt.. Try uninstalling and re-installing your software. Make sure your drivers are up to date also. You can download them from the lexmark website.
Jan 06, 2008 | Lexmark Z600 InkJet Printer
Problem please help thanks if you can
You may have corrupted driver files for printer, try uninstalling printer from pc and reinstalling. This should correct the problem.
Aug 12, 2007 | Lexmark Z600 InkJet Printer
22 people viewed this question
k24674
jasbo
jasbo
