Kenmore 80 serice
I have a kenmore 80 series washer that will fill with water but no other cycles will work. I moved it and discovered some lite oil under it. Any ideas would be greatful.
  • vstrawn May 19, 2008
    The lid switch still makes a clicking sound when it is opened and closed. The coupler gromet on the motor still looks in tact. When I pull the knob on it makes a light humming sound. I havn't tried to turn the motor manually yet, I will try that this eve. Do you know of anything else I could check to help troubleshoot? The lite oil that I mentioned earlier was about a 6 inch round pool of oil, of course filled with dust and lint. Does that still sound acceptable?
  • vstrawn May 31, 2008
    Sorry it took so long to post back. I wanted to let you know that you were exactly right. There was a sock in the pump. Twenty minutes after I read your comment I had it fixed. Thank you so much you saved me big... What you do is truly great, keep up the good work we all appreciate you.
  • 770 Answers
Oil is ok they seem to leak out of the tranmission seal a little loss wont hurt have you checked the lid switch for proper opertion?
Posted on May 19, 2008
  • Gary Davd
    Gary Davd May 20, 2008
    dont worry about the oil The noise you are hearing is the motor trying to start you may have something stuck in the pump you can remove the pump and try it then see if it takes off post your email i will send you the service guide on how the units cabniet comes off
  • Gary Davd
    Gary Davd May 31, 2008
    Glad I could help
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
289 people viewed this question
Top Washing Machines Experts
