Question about Samsung DLP HL-P5663W 56" TV
Green it shows all the faces and everything in the picture green, we have adjusted all the obvious tints and such, but still can't get rid of the green. Just bought it today.
  • bentont Nov 01, 2008
    Green and blue colors are good but no red. Flesh tones have no reds.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Carry it back.
Posted on Aug 03, 2008
1) I have a Sony KV-32FS13 that has a green tint in the picture. Does any oneknow how to access the service menu for this model? I tried other adjustments and I can't get rid of the annoying green...
Code 5 is "AKB error". AKB, or auto kine bias, is a cicuit that monitors the three color guns of the picture tube (red, green and blue) and tries to adjust them for proper color balance. If it can't, the picture is blanked (usually) and the timer/standby light blinks 5 times. When the color drives aren't balanced, you see a color tint in the picture like you're describing.
There might be a problem in the AKB circuit, or the picture tube may just be old enough that the AKB circuit has run out of adjustment range. If the tube is at fault, you should consider replacing the set. A new tube will cost nearly as much as a new 32-inch LCD TV, and you'll need to pay someone to install it and set it up. There are special tools required to perform the convergence which gets the color guns aligned with the face of the tube so they hit the right colors.
If you'd like to try tinkering with the service menu adjustments, this site explains how to access the menu and gives a list of settings.
Jan 02, 2011 | Sony KV-32FS13 TV
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Green tint to picture when dvi cable is connected
The tv will show correctly in 720p mode. Cable box and PS3 must be set to display in 720p or the green tint will remain. For the PS3 I return it to 1080p when I am about to play a game, blu-rays and dvd's can only play in 720p.
Dec 15, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
A lot of green tint in the picture
Hi, what you do is unscrew and take off the grill, take off the black board behind it. You will see a little box for adjusting RGB you will adjust the screen rgb to get the tint to go away and have a perfect color then you will adjust the focus for sharpness. (reset the tv to factory settings before doing this so that your tint, color, brightness and everything else is in the middle.
Oct 17, 2008 | Televison & Video
Zenith Model SY2551S 1996 27" - Green Tint
The core problem with the green tint is the aging of the picture tube, and can be compensated a bit by using either the green drive control usually located on a printed circuit board on the neck of the picture tube or on the main chassis. There will be 3 main controls which will adjust the red and blue as well. If these controls are not present then you will need to get into the service menu and adjust it from there. Don't adjust anything else as you can make the set much worse. Also remember that in order to make these internal adjustments while watching a black and white picture (turn the color all the way down) you will have your hands and arms near live circuits that could shock you and cause injury to yourself as well as break parts inside the set when you pull back after being zapped (voice of experience here) Of course if you can do all this by the service menu then you won't even have to remove the back of the TV.
Sep 08, 2008 | Zenith C27A24T 27" TV
Green tint
Adjust the color temp, it worked for me. I had to turn mine off but now the color is perfect.
Jan 24, 2008 | Dell 3200MP Multimedia Projector
Samsung DLP HL-P5663W 56" TV Logo
438 people viewed this question
Henry  Thomas
Henry Thomas
