After driving for a short while in my 2001 ford explorer sport, the O/D light begins to blink, the transmission is fine, I believe the switch is loose.
the overdrive light flashing on a A4Od transmission is a fault signal for the transmission , just like a ck engine light but for the transmission only , get a code read to find the fault stored in the ecm and then you'll know what exactly it is
its very common for engine swaps to have a few intermittent sensor failures on restart due to the connectors all getting maybe not all the care and protection they deserve in the swap (plastic baggies) and having a bit of dirt and corrosion in them now (spray contact cleaner)
with the od in/out/in/out an educated guess is that the engine throttle position sensor is not being read now , but a code reader will tell all
if it's only the rear turn signal that does this, check the plug where the bulb snaps in. if loose or bad connection to bulb, it will sometimes work and sometimes not. if its both the front and rear turn signal bulbs, could be the combination switch. these were common failures on fords
The ford explorer sport track. Will have a short either at the plug of the multi-function switch or 6 inches down where the column bends the wires during tilt.
i have a 2001 expolrer sport took it to my transmission guy he said it can be a common problem on some fords had a shift kit put in and havent had any problems since
