Question about Dryers
Whirlpool ultimate care II dryer not heating up
I cleaned everything I could turned on the dryer and there was heat. I did this in the dark to see if could see a light kick on. I didn't but I had heat. While cleaning up the dryer was trying to do something because it was making a noise. I checked the dryer and there was no more heat. Could this be from the Thermal fuse burned out or a thermal couple?
  • vwohn Jun 24, 2008
    It heats sometime and goes cold after about 20 mins. Let set awhile and it works again for 15 min.
I have the same problem. Any luck?
Posted on Jul 06, 2008
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
Burning smell
Stop using the dryer! You are probably close to having a fire if you continue to use it. The whole vent system should be taken apart, cleaned, the heat limit sensors checked and the duct cleaned. Your dryer is overheating and is a danger.
Aug 11, 2009 | Dryers
The dryer runs and tumbles. It just doesn't heat up?
if it runs and you have no heat it is the ignitor, a cheap fix. It should cost less than $100.
If you have any heat at all it is the venting, clean out the vent from the dryer to the outside of the home and it will run just fine.
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II dryer will not dry clothes
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Dry Model GGQ9858JQ1 turns off in heat mode after a few minutes
HI. thanks for the question. the motor seems to be at fault here. did you clean the venting from the dryer to the outside. , did you clean the lint inside the dryer. if not do that, thanks.
Oct 07, 2008 | Dryers
Ultimate care II Whirlpool dryer
yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
May 24, 2008 | Dryers
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
89 people viewed this question
Top Dryers Experts
