Question about White Sewing 1632 Mechanical Sewing Machine
Bobbin Info and threading!
I received this item from a grandmother and with it came no instructions. I am totally clueless on how to do anything with a sewing machine. I am in need of alot of help. To start I need to know what bobbin model and bobbin case I need. Did not come with either.
Thanks,
Mindy
  • 3 Answers
Take your machine to any sewing store that sells parts and accesories and they will be able to match the bobbin case to your machine. I am still using the bobbins that came with mine but you can pick up the metal bobbins at Walmart for under $4 for 6 of them.
Posted on Aug 30, 2009
I have a Singer 2263 which is old but not used often. I am making aprons for Christmas, I made 3 and all the sudden the bobbin started bunching together. What can I do?
hi Sue.
Why does my bobbin thread keep bunching up? Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turned.
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little pop up will come up just close this down.
or try this one.
How to Fix that Tangled Nest of Bobbin Thread Under Your Sewing
or read up more at this link.
Why does my bobbin thread keep bunching up Google Search
Dec 13, 2017 | Singer Sewing Machines
How to fix time hook on special adition XL5700 the needle not picking up the bobbin thread
CHECK THESE FIRST::
NEW NEEDLE.
MAKE SURE NEEDLE IS INSERTED THE RIGHT DIRECTION. LOOK AT YOUR INSTRUCTION BOOK.
MAKE SURE INSERTED IS TOTALLY INSERTED.
CHECK TO SEE IF THE BOBBIN THREAD IS STUCK. ALSO, ENOUGH LENGTH OF BOBBIN LENGTH EXTENDED TO ALLOW THE NEEDLE TO PULL IT UPWARDS.
MAKE SURE THE BOBBIN THREAD IS INSERTED THE RIGHT DIRECTION AND SET WITH CORRECT TENSION.
CHECK TOP NEEDLE TENSION TO INSURE THERE IS TENSION ENOUGH TO PULL THE BOBBIN THREAD ABOVE THE THROAT.
IF THESE DON'T WORK YOU MAY NEED TO GO TO YOUR LOCAL REPLAIRMAN.
Jun 18, 2016 | Sewing Machines
Necchi bobbin thread jams up
Make sure that when you start a seam that you grasp both threads and pull gently as you begin. It keeps them from being drawn into the needle plate. get into this habit and it will save you a lot of grief
Aug 10, 2012 | Sewing Machines
I'm in trouble deep-I was trying to fix an old
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
I have a Singer sewing machine that I just had repaired at the shop, and it worked for a while, but then the bobbin ran out of thread. I re-threaded the bobbin according to the instruction manual (thank...
Do you have the thread coming off of the bobbin the right way? How about a new needle? Sometimes it has to do with the tension, needle and good thread. And the bobbin being wound evenly. You can always call Singer at 1-800-4singer and ask them if there is something else to do.
Dec 16, 2010 | Sewing Machines
I purchased singer bobbins to use in my singer 5050. I thread the machine and bobbin per manual instructions, but when sewing, the thread severely bunchens and knots up on the bottom side of the item I'm...
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Sep 30, 2009 | Singer 5050 Mechanical Sewing Machine
My machine will not pick up the bobbin thread
how long have you had the machine?
I don't see what kind of machine you have?
does the bobbin drop in from the top, side, bottom?
email me at
monis_gifts@bellsouth.net
tell me what kind of machine and model number you have
I'll see if I can help
Sep 02, 2009 | As Seen On TV Sewing Machines
Repair and opertors manuals?
The cheapest manual I have found for the model 6440 is at http://gotoes.org/sales/VikingSewingMachineManuals/ViewInfo.pl?Viking=1&Sewing_Machine_Model=6440
It is a downloadable version also sent by email.
There is a free threading diagram including bobbin info at www.sewusa.com. Repair manuals are available on ebay and run ten dollars or more.
Oct 27, 2008 | Sewing Machines
New Sewing Genie doesn't sew
they are not accurate, but also this machine is not the greatest with all types of thread, try using rayon or polyester thread when trying to wind a bobbin (cotton thread on these machines are typically sometimes hard) let me know and if this does not work ill send over what I have as far as directions
Jan 20, 2008 | As Seen On TV Sewing Genie Mechanical...
White Sewing 1632 Mechanical Sewing Machine Logo
147 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
