The water supply to my my 2004 Maytag Neptune TL top loader will randomally not shut off, casuing the washing machine to file up to the top overflow and flood my first floor. At first it was thought that the pump had failed, on the second flood the digital control panel was replaced, but I think that the problem lies with the water fill solenoid. The tech thinks I am crazy but does offer that I should hall this $1,100.00 Washing Machine to the dump as not fixable, what do you think?
    Novelist:
  • 177 Answers
You have several possibles problems
The pressure switch could be faulty or the tube that runs from the pressure switch down to the accumualtor could have a cut or tear in it. solution replace hose.
or The mixing valve could be hanging open also with a piece of debris. solution replace mixing valve
For now turn the water when your not using your machine.
Posted on May 24, 2008
Maytag Neptune TL washer overfilling
yes i would agree the water valve is defective as if unplugged it should close,but also sounds like a pressure sensor or pressure hose problem that is also defective too due to the fact that it should at least start the wash cycle even though the water doesn't stop filling,so also it could be the central control unit,pressure switch or pressure hose
May 07, 2012 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag washer is overflowing
Check the pump and the water level switch.
Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Hi - my maytag top loader FA5800AWW is stuck on wash cycle. it won't do the spin only and it is sometimes getting stuck locked.
I feel you have a Clutch issue Google this phrase ""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Repost on that site in the Maytag forum and I will help.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Why is my Maytag Neptune top loader continually reading "dc" and is not completing wash cycle?
You can't get the FAV6800A/FAV9800A Service Manual from this site.
Google this ""Sticky: Neptune TL Washer FAV6800AWW""" Post your problem at this Forum. You will find the FAVA9800A/FAV6800A Service Manual at that site.
Jan 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Are you supposed to dilute the fabric softener with water before you put it in the dispenser.........I have a Neptune TL,
Yes it would help it from getting so gumed up, But its not as big of deal on a top loader as it is a front loader
Sep 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
Washer doesn't cut off water
The problem is the water inlet valve . The part which the hoses from the wall , connect to . Without the model number , I cannot tell you how to access the valve .
Sep 16, 2009 | Maytag Washing Machines
Maytag Neptune TL FAV6800AWW Overflows
Check the pump, pressure switch and related hose for small obsctructions. For reasons unknown they moved the pressure switch location to above the pump. d60f89f.jpg
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Depenable care-Top Loader
Hi dannybridges
With the 5500 series it is usaly the motor comtrol board. i would get a tech just to be sure casue it chould be the main board at the top but i doubt it.
brent
Sep 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer,neptune tl ,top loader
Sounds like lack of communication between the keypad and the control board. Suggest you check for loose connection between them.
Jan 22, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
