Question about Seagate (9Y7275557) 400 GB Hard Drive
Will not power up.
I used my ext. hard drive to put all of my cd's on. then when I bought a few more cd's I wanted to put them on my hard drive.
When I power it up a blue light will appear. But when I try now nothing happens.
I think I feel it moving inside but not 100 % sure.
Can this be fixed ? Do I need to take it somewhere?
  • djcamps May 23, 2008
    Overland Park is where i live,
    The only thing I did was leave it on power. Do not recall dropping it.
    Thanks for your response
    Scholar:
  • 119 Answers
Well what happened to it? if it fell then chances are that you will not be able to fix it, due to the fact that harddrives have a shock or Gforce limit should a shock exceed that limit that the internal components will get damaged. getting it fixed is possible but will cost a small fortune due to the equipment necessary there are places where you can get it fixed. where about are you located?
Posted on May 19, 2008
Why wont my computer recognize my LDHD-UP2 external hard drive?
can you try this sequence
turn off power to both computer and ext drive, after logging off computer
leave ext drive power OFF
connect ext drive to another USB port
turn computer back on let it boot up ext drive is plugged in but no power
once computer stabilizes, then turn power to ext drive on
let me know if this helps.
May 17, 2012 | Computers & Internet
Not detecting in my pc
hmmm so you have this on USB port. you might want to try this first:
A. shut down computer and ext drive power
B. Turn on computer and let boot up, w/o hard drive power on
C. Make sure ext drive is plugged into usb port
D. Then turn power on ext drive
Windows should 'see ' the drive and add it your my computer
let me know if that helps at all
May 17, 2012 | Transcend StoreJet 320 GB USB 20 Hard...
My external hard drive is not being seen by my computer?
1 of 2 things can be wrong...1 (cable may be loose) unplug the cable (ext HD) connected to pc, now reinsert back into pc..try this once or twice...until you see it appear in my computer....if this is not working and your ext HD came with a CD software..uninstall (make sure ext HD is not connected) software, then reinstall make sure your firewall allows it to be connected....this should do the trick...now plug HD back up to pc...do not format your ext hd unless you really really dont want the data on it (format erases everything)
May 27, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
I bought a new WD Elements 350gb external hard drive and it came with a Memeo software CD. It says to insert CD before starting backup. I do not appear to be able to use this external hard drive as a plug...
This software is not linked with the drive (with this particular drive you only get a trial version anyway). Just remove the software from your PC.
Start > Control Panel > Add or Remove Programs > Remove Memeo/ WD Anywhere Backup.
Once you have done that, you can delete everything on it (assuming you never manually put something on it apart from the backup). If so, back it up onto your PC, another drive or CD.
Jan 25, 2010 | Western Digital Elements powered by WD 320...
Way to retrieve files off an ext. hard drive gone bad?
try to install the drive as a secondary drive in a pc u know works (dont mix fat with ntfs drives) if there both the same OS u should be fine, see if u can access the files then, if u can great pull off what u want to keep & reformat the drive, if u cant well..........read this, i couldnt explain it any better
http://www.popularmechanics.com/technology/how_to/4294038.html
Dec 10, 2009 | Western Digital Computers & Internet
Iomega External Hard Drive model #3173600. Following a
ok it's asking you to reinstall the cd that came with the ext hard drive to do this remove the hard drive frist after you power down you pc put your cd in after you power backup install the driver power down plug your hard drive back in window will do the rest for you Good Luck
Jul 18, 2009 | Computers & Internet
I need help with my hard drive?
You can't just put the hard disk into a totally different machine due to hardware differences. If you want to recover data from the hard disk use an Ubuntu live CD, however if not, make sure the boot order is set to DVD/CD -> HDD then use the restore CD's to recover the systems.
Jun 09, 2009 | Compaq Computers & Internet
USB Hard Drive
You cannot run a External Hard Disks (...that's what the User Manual say) It only reads Flash Drives, I have tried 8GB.
Oct 01, 2008 | JVC KW-AVX800 CD Player
Transfering data
If you are having issues accessing the drive i've encountered that situation before
I tried a different cord and it started working again. Additionally i've had this work for me (see below)
Try This:
  1. Unplug all USB devices
  2. Turn off Ext Hard drive
  3. Shut down computer
  4. Power on ext hard drive (then wait like 1 min)
  5. Turn on computer
  6. Wait for windows to finish loading
  7. Plug in the USB cord from the ext hard drive to your computer (may take up to a minute for computer to recognize it)
  8. If it doesn't recognize it then keep trying it in different USB ports
If it still won't recognize get all the latest windows update and reboot. If that doesn't solve your issue try your external hard drive on some other computers, check to see if drive needs special drivers installed (which most don't).
From SimpleTech's website: "1) I have the drive plugged in but I cannot find the drive in "My Computer", why?
The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS."
If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Mar 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Seagate (9Y7275557) 400 GB Hard Drive Logo
62 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
