Question about RCA P52926 52" Rear Projection Television
Adjust projection tv does not appear in the sceen menu
You told someone else who had the same problem to check the fl231 fuse. Where in the tv can that fues be found?
  • RCA Master
  • 8,617 Answers
Its right next to the Flyback which is a large transformer about the size of a fist with a large red wire coming out of it. The fuses are located near that they are 3 fuses fuse FL231 is the center fuse.
Posted on May 19, 2008
Rca d52w19 rear projection changed flyback and cp150 cap. fuse fl231 is good . have bowed screen and 3d effect. convergence shows in menu but cannot adjust at all.
IF the FL231 fuse is good and you still can not adjust the convergence then the Convergence power supply board would be the most likely problem. You can get the replacement boards from
Mar 31, 2011 | RCA D52W19 52" Rear Projection Television
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Jan 14, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Autoconvergence option is GONE!
You will need to replace the ITC222 convergence power supply board and the FL231 fuse on the deflection board. You can get replacement parts at the following link with free installation instructions.
Sep 24, 2008 | RCA R52WH73 Projection Television
How to remove fuse
solder will have to be removed from component solder side..
Jul 29, 2008 | RCA HD52W56 52" Rear Projection HDTV
Some of those models are a different version of the PTK195 chassis some dont have the fuse. in that case you will need the convergence power supply board thats what likely blew the 5 Amp fuse. let me know if you need help locating one of those power supply boards.
May 21, 2008 | RCA P52926 52" Rear Projection Television
Color seperastion
Check fuse number FL231 chances are thats blown and is whats causing the problem
May 17, 2008 | RCA P52937 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
