Question about Frigidaire ATF6000ES Front Load Washer
Pause Error - Frigidaire Affinity LTF6000ES0
I have a Frigidaire Affinity LTF6000ES0 that I paused to add clothing to a wash cycle. I must have bumped another button as well as I now get an error message when I press any button, including cancel. I have unplugged the washer overnight and still have the same error. I know there is some code that will reset this error.
  • Help please!
  • courtneyls May 26, 2008
    Called a repair man ... $157 later they said I turned the dial too quickly. Didn't turn the dial at all. At any rate he called Frigidaire to acquire a code number that resolved the problem.
    Thanks so much for your efforts.
  • 868 Answers
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
Posted on May 21, 2008
Frigidaire washing machine model number 137168300a stuck in pause mode
Good Afternoon Friend, this is Z. Thank you for your inquiry!
If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 12, 2014 | Frigidaire Affinity ATF7000EG
My frigidaire dyer comes on then the pause message appears. These are new appliances.
Hello barbarada180 - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Jan 02, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Pause lock keep showing up on screen
Hi Lance - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Sep 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a ATF7000FS1 washer that has been pausing the wash cycle on it's own. I will have to press the start/pause button during the cycle to restart. This happens several times during a wash cycle. How...
some machine will stop before spin its called crease guard if you are useing a low temp cycle its there to give you the option to stop your cloths wrinkling try another cycle
Nov 08, 2011 | Frigidaire Affinity ATF7000E Front Load...
Affinity Washing Machine, 3 months old, pauses during cycle. Does not give any error code. Have tried different cycles, eventually it will run the cycle. Doesn't happen with every cycle, yet. Switches...
Did you figure out this problem? I think these machines are JUNK! We purchased our first Frigidaire Affinity in April 2010 & by September it started ripping our clothes apart. Not every cycle. At first we thought it was the dryer but nope - it was the washer. Something to do with the drum. We had it replaced in October 2010. Then after the truck dropped off the replacement, I tried doing my first load of laundry. It lite up & did nothing. Something to do with the motor. Again, we had a 3rd machine replacement. I wanted to give up, get my money back & go buy something else but I wanted it to match my dryer so I was kinda stuck. Our 3rd machine is now going to pause constantly during a cycle. I've read up on it & tried various things such as less soap, checking the drain etc. & nothing has changed this problem. I'm calling the store on Monday & demanding my money back & they can take back the dryer too. I have a feeling this might be a bit of a fight but I am disappointed with the results of this machine. We've lost about $100+ in clothing from the first machine, plus all the down time in all 3 of these machines not working & having to worry about going to do laundry elsewhere.
Sep 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
What does error code E59 means on a Frigidaire Affinity front load clothes washer?
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Apr 22, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Won't wash
press the pause and stop button at the same time it will give u a code
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
1,544 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
