Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Delonghi Pinguin Air Conditioner
I turn it on and it seems to never really get "air conditioner " cold. it`s more like a fan. Then it blows warm air. Any ideas?
  • 1 more comment
  • itgeek74 May 19, 2008
    I'm having the same problem with mine. Did you find a solution for this? Thanks.
  • itgeek74 May 23, 2008
    I decided to open up my PAC L90 and I found that there was a crack in a 1/4 inch copper pipe that connects the compresor to what looks like a radiator. There was an oily substance that leaked out - and there was alot of it. I mended the break by adding a 3/8 inch copper pipe that was about an inch long and sweat them together. After doing so, the problem still remained. I assume that whatever the oily substance was, it needs to be replenished. Can someone please tell me what this oily substance is and if I can replenish it myself (if possible)? Thanks!
  • suebee88 Jun 08, 2008
    Mine went out this afternoon.  I'm freaking out from the heat!  My 1-year warranty ran out on June 2.  Go figure.
    I bought descaling fluid from Delonghi a few weeks ago, and was able to clean the coils under the filter.  The unit performed much better after they were cleaned.
    Caveat:  The instructions on the descaling fluid bottle are written in Italian! Call customer service to order (and interpret!), 800-865-6330.
    I ran the unit at 64 degrees constantly all last summer, and over the last month.  I hope that all it needs is some freon....
    Problem Solver:
  • 9 Answers
I sat on hold with Delonghi for about 25 minutes before I talked to someone this morning.  Expect a long wait before you get helped.
For this specific problem (unit works, just doesn't blow cold air), the unit MUST be sent to an authorized repair facility.  No repair facilities in Texas.  The closest one to Texas is:
All-Brands Appliance 5008 W. Linebaugh Ave. Suite #8 Tampa, Florida 33624 813-908-2002
Delonghi said they will cover mine under full warranty up to 13-months.  No RMA needed, just a photo copy of the purchase receipt for the unit. Outbound shipping is something not covered by Delonghi, but they will pay for parts, labor, and return shipping.
All-Brands said they don't have any specific requirements for packing, other than making sure the casters on the bottom of the unit are well-protected.  It is common for them to break during shipping.  They recommended, though, that if you have someplace nearby that does professional packing, like a UPS Store, to take it there.  It's not a requirement, just a recommendation.
Along with the unit send a copy (not the original) of your purchase receipt, your name and telephone number, and the address to where the unit will be returned.  Also, include a detailed description of the problem with your unit.
I REALLY hope this information helps someone!
Posted on Jun 09, 2008
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
Brand new delonghi PAC C120e, I got everything installed easily with the unit rite next to the window, I have it turned all the way down and it still does not cool my small room at night. It seems to blow...
Since the unit is new and under warranty and hopefully you have registered it with Delonghi. Your best bet, is to contact their Customer Support Rep 800-322-3848. Doing it this way has you totally covered.
Jul 12, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
Compressor not turning on - but unit turns on and fan works - even when temp turned all the way down.
all the way down is as warm as the refrigrator can get. Sounds like start components are the problem.
Apr 17, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
How do you check a portable air conditioner for freon
If there are high and low pressure ports, you can put guages on them. If it's a sealed system, all you can really do is feel the suction line (the fatter one) it should be cold. The high side (thinner one) should be warm.
Jul 15, 2010 | DeLonghi Pinguino PAC-77E Air Conditioner
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
Not blowing cold air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2009 | DeLonghi Pinguino PACL90 Portable Air...
How to conect my air condittinion pinguino pca L90
This really Expensive AC quite on me. The fan works great, I hear the Compressor turn on and it still doesnt blow cold air. Should I flip out?
May 14, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
On/off cooling
You will need to replace the outdoor fan and capacitor before it cause damage to the compressor. Thx RepairUSA
Aug 25, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
1,042 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
