I have a Briel multiPro machine and it worked for many years. Recently I noticed that coffee is not strong enough and the pressure gauge shows pressure below 9. I know that it is not a coffee problem as I use Lavazza and the same grinder. I'll appreciate any advise. thank you. Olga
First, I'm NOT a Briel technician, But if you still have pressure from the removal of the portafilter (or capsule) then the exit or pour spout is clogged. You can soak a standard portafilter in warm water over nite and wash it clean in the morning. Really bad? then soak in urn cleaner and flush thoroughly prior to use. For capsule machines follow the MFR's instructions to properly flush the machine. You may also try to "fool" the machine into making a 'no coffee' shot by reusing old capsules over and over again to try and flush out old coffee from the spout. Otherwise the unit may need servicing to remove the clog as most of these capsule machines do not have serviceable parts. Contact your vendor or MFR directly for service or replacement.
*warning! Try not to stick a pin, nail, or paper clip into spout(s) as this may damage valve or offset the dual pour spout. Most of these machines have double spouts and can be easily pushed out of alignment.
* Final; I've noted that your probably using a portafilter type machine. If you have water or steam dripping from head then there is a leak in your head valve or commonly called the 'Group Valve'. Fortunately this is a serviceable part and can be replaced by your vendor.
PS. Have you tried 'Back Flushing? Use a "BLANK" portafilter basket (the one with no holes) or a back flush rubber stopper (from Cimbali). Add a 1/4 teaspoon of urn cleaner of flush cleaner to portafilter and lock onto group. Run shot till it stops (excess pressure and dose will by-pass the group valve. This will flush old coffee and crud out the by-pass pipe and into drain tray. If nothing happens and the group hums for longer than 20 seconds then your probably got a clogged valve and back flush pipe. All will need disassembly, cleaning and/or replacement. Best to call your Vendor for service.
*Be sure to run the group several times and wash the portafiler to get rid of the urn cleaner.
*Tip; It's a good idea to back flush every hour with with plain water from the shot to just get rid of the coffee grounds stuck to the group shower head and leftover coffee in the group valve. Does not hurt the machine and keeps everything working smoothly.
Briel is the Portuguese leader in building espreso machines and small appliances.
Briel had opened only recently to the international market. Their manuals are not available for download, and many models do not have an English manual available.
The group head gasket needs to be cleaned or replaced. First get a brush and clean put the head, then insert back wash filter(basket with no holes) in portafilter, make sure that it is seated properly(atleast 90° angle with machine), then run the head if nothing leaks around the portafilter the gasket is fine, if it leaks then replace the gasket. Make sure that you press the stop button before removing the back wash filter.
Possibly bad heating element which is inside thermoblock. Can purchase for $75. Contact Fank at ElectraCraft Phone
(201) 439-1700 to help you troubleshoot.
