Question about Westinghouse LVM-37w3 Television
Westinghouse LVM-37w3 TV
Our sound and picture went out It still turns on and off. How much should this cost to fix?
SOURCE: Westinghouse LVM-37w1
I have the same issue, and I have read about 1 more of thse I wonder if they have a issue where they all break this time of year :-) I WILL NEVER BUY A WESTINGHOUSE AGAIN
Posted on Dec 17, 2007
SOURCE: Westinghouse Sucks
You all know you picked the Westinghouse brand cuz it was cheap.
Avoid cheap brands like Vizio, Magnavox, Philips, and Sylvania etc... If you don't buy eventually they will go away.Next time get a plan fro the TV. If you had a service plan on the TV you would already have a new one. Plans always cost less than repair and shipping. Don't be cheap. BUY THE SERVICE PLAN.
Posted on May 30, 2008
freetek
  • 5568 Answers
SOURCE: No picture on a Westinghouse lcd tv model ltv-20v4
The simplest problem would be the failure of the backlight.
In case you don't already know it, there is one, and they may or may not last forever.
Also, there is an extra power supply to produce the high voltage the lamp needs to fire that may have failed.
Sometimes, you can look at the screen from an angle to see if there is any sign of movement.
If you can see program material causing a change in the faint image, then you can be pretty sure it is one of the two problems mentioned.
Posted on Sep 01, 2008
SOURCE: westinghouse tv ltv46w1hd sound no picture
my westing house 46 has sound and no picture
Posted on Sep 27, 2008
freetek
  • 5568 Answers
SOURCE: Westinghouse LTV-20V4 turning on PROBLEM
This problem is with fair certainty the power supply.
Modern power supplies are designed to shut down if the current drawn exceeds the design level which indicates that something the supply services or the supply itself has died.
If you are adventurous, you might pull the plug on the set, allow the set to sit overnight, gain access to the innards, and with good light, inspect any boards inside. If you see one that has few ICs but many more larger discrete parts, this will be the power supply.
You are looking for components called electrolytic capacitors that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many (not all) will show signs of pregnancy when they fail, bulging unnaturally when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will look like four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006.
The larger caps will probably be OK since the failure is likely related to functions other than brute-force filtering. A pretty good 'rule of thumb' is to replace any caps you see bulging that are 100 uFd or less.
If you choose to replace these yourself, you will need a quality soldering iron with a small, preferably iron-plated tip, rosin core solder and a sponge which when wetted is used to frequently wipe oxidized solder from the tip this should be kept bright and clean and fresh tinning will keep it that way.
You should also buy some solder 'wick' with the iron; this is used to place on the solder you wish to remove and then heated with the iron. Properly used. the wick will absorb nearly all of the solder from the lands from which you wish to remove a component.
Posted on Oct 07, 2008
LVM-37w1 after 5 minutes of viewing, picture and sound go off. Blue power light turns orange. attempts to turn on TV are unsuccessful. Blue light immediately turns orange.
I saw this fix posted on another blog by a fellow named Patrick. I tried it today and it it worked. It fixed my Westinghouse lvm-37w1. Basically disassemble the back of the TV (removing all the screws on the edges and middle). Remove screws holding bottom speaker and stand. There are 2 chrome rods extending down. There are small screws inside holding them on. You can turn the rods and unscrew the screws but need a small screw driver to put them back on. Remove the black cover on the back. remove the plates on the lower middle section. You will expose a printed circuit card. unplug wires and unscrew 4 screws holding it in. Remove it, turn it upside down and inspect the solder joints near the lower middle (especially under the gray relay on the other side). I found 4 solder joints that were cracked. Resolder the larger solder joints that are cracked or look bad (small solder joints are too delicate). Put it back to gether and it should work now. Mine works great. No more black screen with no sound.12_2_2011_5_11_21_am.jpg
Sep 29, 2011 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Can't find my coaxel hook up on my tv
Sorry,... there isn't one. This model is what is known as a "Monitor". There are no built in tuners, it has to have an external source of some sort.
Aug 24, 2010 | Westinghouse LVM-37w3 Television
How to replace backlight in a westinghouse 37" lcd tv? and where to get replacement backlight? model LVM37w3....
Backlight board,It call a LCD inverter board,it long board in shape.After take the tv backcover out.Replaced this board pretty easy just require a philip screw driver take out about 6 pilips screws,and few cables connections.Do the reverse to connect.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.
Mar 30, 2010 | Westinghouse LVM-37w3 Television
I have no picture but I have audio
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LVM-37w3+
Please post back what you find.
Dec 25, 2009 | Westinghouse LVM-37w3 Television
No audio, picture okay
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Nov 30, 2009 | Westinghouse LVM-37w3 Television
Stained / darkened image area on about 1/3 of screen
first how old is the tv with your first and second generation flat screens and plasma tvs alot of the logos have burned into the bottom corners of the screen and after awhile they burn so much in it grows to bigger portion of the screen and unfortuneatly there is nothing you can really do for this until its time to buy a new bulb if lcd for the tv sorry
May 14, 2009 | Westinghouse LVM-37w3 Television
LVM-37w1 37inch LCD HDTV
It is worth fixing but you have to replace the power supply. It is a fairly common problem with the Westinghouse units.
Aug 14, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
WON'T POWER UP
I had the LCD repaired. It turns out that the power supply went out. It cost me a few hundred bucks but it was worth the repair rather than buying a new one for 3x as much.
May 27, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Westinghouse LVM-37w3 Television Logo
99 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
