Question about D-Link DCS-3220 Network Camera
IP camera keeps resets itself
HI I have a DCS-3220 ip camera....
Every time I set the IP address it keeps changing to the default IP address
192.168.0.99 by itself after restarting.
MJ
  • Anonymous May 28, 2008
    Hello, I have the same problem and I forgot the password,
  • Anonymous May 21, 2009
    Exactly the same problem.
  • 3 Answers
Hi
I have a pretty good knowledge of these cameras as I have 5 around my house.....
IP address resets are likely caused by the default address being loaded (192.168.0.99) and the box is not checked to reset the IP on reboot. You have two options.....
Using IP surveillence, open the camera settings. You will be prompted that the recording will stop, just press OK. Once you get to the settings window, you should see your list of cameras and the config screen for the one that is highlighted. Pick the camera you want to change the setting for and go to the tab where you can assign the IP address and gateway. Type in the IP address you want it to use. Uncheck the box that says 'reset IP on reboot'. That box is at the top. Hit apply. Once you do that, cycle the power on the unit leaving it off for at least 10 seconds. When the camera reboots, type in the new IP and you should be able to view it. (sometimes the camera will default on that IP if your router is using 192.168.0.1 and DHCP for computers that has that IP in it's range of assignments of IPs. Telling the camera which one to use and telling it to not reset on reboot will make the new IP stay in the camera.)
Your second option is to use the Installation Wizard or IE, find the camera either by typing in the IP for the camera in IE with the http:// or linking to the device with the installation wizard. If you follow the same procedure of assigning the IP and unchecking the box on reboot like described earlier, this should cure your problem. You do NOT want the IP resetting on reboot unless the camera will not link to your home router (likely causes for this is the IP range the router uses, say 192.168.1.1 like most belkin or linksys routers use, does not cover the IP range of the camera in it's DHCP server.
What I found best was to buy a junk router, set it's DHCP IP range to cover 192.168.0.99, set the camera, save it, kill the cameras power, connect it to the router you plan to use, then start the camera back up. Make sure whatever IP address you use on the camera is one covered by the DHCP server list on the router. ie: camera is set to 192.168.2.2 and the router assigns IPs from 192.168.2.2 through192.168.2.254. If your router only assigns IPS from 192.168.2.100 through 192.168.2.200 and the IP on the camera is 192.168.2.2, you won't be able to connect to it.
Hope this helps
Posted on Sep 20, 2008
  • userandpass Sep 20, 2008
    For the poster who cannot remember their pasword...
    You will need to reset the camera before doing any of the above. There is a small button on the ack of the camera that you use a paper clip on. Push it in and hold it for at least 5 seconds. Once the camera is reset, then you can provision it.
    You may not have forgotten your password, it may just be corrupt on the camera. I had one here recently that would not accept my password that I knew I set on the camera. Resetting the unit cured the problem.
    You may want to make sure your camera is using the current firmware, as some bugs with web server hangs were corrected in the latest release, which may attribute to the problem. The latest camera firmware is 1.04 and can be downloaded and installed either with the installation wizard or on the camera web pages.
    Hope this helps.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 135 Answers
Go into the router and give your cameras a static IP. You do that by turning Dhcp off. Select and or give them the suggested IP. Make sure in app settings you turn on force close network connection. Just a couple quick tips. Static IP then they will not reset.
Posted on Feb 25, 2015
Change ip address
Is your ip is static or dynamic?If it is dynamic,then you have to reset your modem or else if it is static,then ask your ISP to change your ip.To know your network ip address visit Ip-Details.com .
Apr 07, 2013 | D-Link DCS-6620 Internet Camera
Hi!! How can I change IP address on DCS-3220 security camera?
DCS-3220 is fixed IP security camera !!
can't change its ip !!!
Jun 14, 2011 | D-Link DCS-3220 Network Camera
Hi, I'm having trouble with changing the IP address on the SecCam
you can try this http://www.whoisxy.com/ ,here i got the details about the dns query ,ip to domain ,domain to ip etc........you can get more about the ipadress......
Jul 13, 2010 | D-Link DCS-5300 Network Camera
What is the default ip address of D-Link DCS-3220 ip cam ?
Hello
The D-Link DCS-3220 have DHCP, that means it gets a automatic address from your router.
IT doesent have a STATIC ip, if you not set it manually.
To configure your D-Link DCS-3220 CAM and find the IP you need to install this program.
Install Wizard You need to unpack it first.
Connect your computer and cam to same router and run the program. Then it should find your cam so you can configure it and see what ip it get your you set.
Then you can browser to the cams IP.
Here is the manual and instruktions for you CAM
Here is Quick install guide
Here is you Dlink cam site to get firmware updates and more.
Hope it works.
Jul 09, 2009 | D-Link DCS-3220 Network Camera
Is it possible to record the streaming video on DCS-3220 ? and if yes how to configured the streaming server ip ?
I had a similar issue trying to feed a live stream to the web with a dcs 3220, I found that I had to use this IP configuration; Ip address is XXX.XXX.X.X/cgi-bin/video.jpg then use "jpg pull" from the web server. Hope this helps you let me know http://troyster.com
Jan 26, 2009 | D-Link DCS-3220 Network Camera
I cant reset my senao eoc3610
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
Dec 27, 2008 | EnGenius EOC-3220 (EOC3220)
Eoc3220+ ip finder
hi
reset your eoc 3220 and put the default ip address is 192.168.1.254 bridge mode and ad mode ip is 192.168.1.253 and put your pc ip 192.168.1.10,12,14,16 and open the web page and browse the 192.168.1.254 or 192.168.1.253 put user name and password ok!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct 07, 2008 | EnGenius EOC-3220 (EOC3220)
Password and user id
Reset the camera by holding the reset button for 3 seconds (use a paper clip in the hole marked "Reset" on the back). The camera will then reset to all default settings, including an IP address of 192.168.0.20.
Nov 19, 2007 | D-Link DCS-900W Network Camera
DCS reset
Push the reset button on the back of the camera
Oct 05, 2007 | D-Link Express DCS-900 Network Camera
D-Link DCS-3220 Network Camera Logo
1,366 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
