Question about Hatco C 24 Compact Electric Booster Water Heater
My washer flooded my basement causing my pilot light to go out on my hot water heater. Now it won't ignite.
    Novelist:
  • 161 Answers
I don't know how high the water got but if only the burner was covered it is probably just dirt. Try replacing the thermocouple this is usually less than $10. If the gas valve itself was wet REPLACE THE WATER HEATER!!!!!!! Never trust a gas valve that has been wet!!!!! It can seem to work just fine but get stuck in the open position defeating all safety measures.
Posted on Jul 07, 2008
RELAINCE 606 GAS WATER HEATER. WE RECENTLY HAD THE BASEMENT FLOOD DUE TO ALL THE RAIN. WE NOW HAVE NO HOT WATER, I AM SURE DUE TO THE FLOODING, BUT CANT GET THE PILOT LIGHT RELIT! HELP
If keeping the thermocouple bypass pressed keeps the gas flowing to the pilot but the flame goes out when it is released in spite of keeping the flame going the customary amount of time, then either the flame isn't powerful enough to reach and heat the thermocouple bulb, the pilot flame or the bulb is out of alignment or the thermocouple is faulty.
If the flame is weak it indicates a blockage in the jet or the supply pipe.
Sep 08, 2017 | The Kitchen Appliances - Others
Pilot light and burning will not stay lit. Basement flooded and after all water was gone tried to lite the burner. Could not keep it lit. Called a service tech and they came out and cleaned the burner...
Manufacturers say to replace water heater after a flood.
Flooded water heater can be repaired by replacing parts but warranty is voided.
And if water heater reached gas control valve, then gas control has to be replaced >> possibly the gas valve eco tripped.
I don't know how effective cleaning burner parts will be, since a small spider wed inside some of those tubes can cause water heater not to function. Small obstructions cause big problems.
I'm sure the plumber cleaned it out real well.
Find manufacturer using label on side of tank, find manual with parts diagram, and order burner parts.
http://waterheatertimer.org/Water-heater-manufacturers.html
It might be cheaper to install a new water heater yourself from box store
http://waterheatertimer.org/How-to-install-gas-water-heater.html
I read one article:
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/
Guy has water heater that filled with water.
He says: "I decided to feel around. As soon as I put my finger into the hole under the burners I hit water. The air intake passage was filled with rain water, effectively chocking off the fresh air. A few minutes with a siphon tube cured the problem and the water heater works normally again."
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 06, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Basement was flooded when washer inlet hose burst. Approx 6 in of water in the area where the water heater stands. Complaint of no hot water, no pilot flame. Attempt to light pilot successful but pilot...
Certain Rheem water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts.
White Rodgers Intelli-Vent PowerVent Control Equipped Models
  1. Step 1 Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
  2. Step 2 Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful
Oct 01, 2010 | Rheem Water Heaters
Basement flooded;Water Heater insulation is a little wet on right side of entrydoor; Relighting the pilot light has been unsuccessfull; What do you reccomend?
tank looks to be leaking and getting the insualtion and floor wet .. so replace water heater?? Once the tank is leaking there is no repairing it..
Mar 16, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
My basement flooded and now my gas water heater
Was the gas valve under water? If so it must be replaced. If not, and you're sure you are holding in the button for at least 30 seconds after the pilot is lit, the pilot will need to be removed disassembled and cleaned. Also, the thermocouple may or may not be bad, replace it anyway (for the cost @ Lowes etc just not worth it).
Sep 22, 2009 | Water Heaters
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Hatco C 24 Compact Electric Booster Water Heater Logo
202 people viewed this question
Top Hatco Kitchen Appliances - Others Experts
Craig Butler
Craig Butler
Pat
Pat
Level 1 Expert
Tom Chichester
Are you a Hatco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
