Over heating i have a technics stereo intergrated amplifier SU-G70 its gets hot to the point it can burn u. the fan in it is not working technics amplifier cooling fans
    Scholar:
  • 106 Answers
Make sure there is nothing within several inches of it to start off. if need be, use a small house fan pointed at the amp to help cool it, if all else fails and/or you don't want to hear the noise from the big fan; get a computer fan the same size as the one in the case. connect it in place of the fan that does not work(may have to cut/splice the wires). that should work. oh, check the voltage and whether the fan is AC or DC from the stereo. this makes a huge difference!!!! if the fan says "DC" DO NOT CONNECT AN AC FAN TO IT!!! the fan will short and BLOW UP!!!
Posted on May 23, 2008
I have a technics su-g75 amplifier, this system hasn't been hooked up for a few years but seems to be in excellent condition. It plays and seems to work great. I don't know whether this is a problem or...
Yes the unit will get fairly hot. If you can keep turning it up at some point the fan should kick in, if it doesn't then it need looking into further.
Apr 23, 2011 | Technics SC-DV290 System
Technics SU-X9920D amp cuts out due to overheating unit gets very hot fan motor has been replaced there is also scorching to the PCB
Keep a fire extinguisher handy and never walk away from it while it's turned on.
If you're NOT overdriving it and it has sufficient all around clearance for coolign airflow you should take it to a competent technician for evaulation before you burn the house down.
Apr 06, 2011 | Technics Audio Players & Recorders
I have a Technics stereo integrated amplifier SU G75. The cooling fan began making chirping noises then stopped. Now every time I turn the stereo on I get a overload message. Could it be the cooling fan...
It chirped because the bearings were worn out, then it froze up and isn't moving any air. Get it replaced. DO NOT run the unit if it keeps overloading or you will have a bigger problem.
Dec 27, 2009 | Technics SC-DV290 System
My technics intergrated amplifier says over load
overload is protection from very big signal input-or high current output.
1-keep your input signal between -10db-----to 0db.
2-confirm that amplifier power is greater than total power of loudspeakers by 20%(if loudspeaker total power is 8 watt-amp watt must be 10 watt at least.
Nov 30, 2009 | Technics SUV500 2-Channel Amplifier
Technics su-Z750 Intergrated Amplifier stays in Standby
HI...
This happens when one or more components in the power amplifier section has failed.
The protect circuit keeps large DC voltages off the speakers.
The only thing you can check for before finding a tech is that the speakers are firmly connected at both ends. If they are ok, you need a tech
PLease rate my help if this helps
Nov 05, 2009 | Technics Audio Players & Recorders
My su g90 shuts off when i turn it up loud what do
Amplifiers get hot. The more you crank the volume up (or use extended for extended periods), the more current is required. When it gets hot, there is a fan motor (on the back), that should turn on. I believe your fan motor (brush) is worn out and therefore non-functional. Under this condition when the system overheats, it automatically changes mode to protect circuits.
Also note: if it works when you initially turn it on (cold) for a few minutes it should work fine...until it starts getting hot inside the case.
Oct 20, 2009 | Technics Audio Players & Recorders
211 people viewed this question
 Grubhead
Grubhead
