Question about Toshiba Satellite A135-S4527 Notebook
1024 RAM i want to expand my RAM into to 2gb. but i dont want to changed my current RAM or remove. Is there any available slot if i add 1GB RAM to my toshiba model SATELLITE A135-S4527?
  • 36 Answers
No, you would need to remove both of your old 512mb ram sticks and replace them with 2 1gb ram sticks (PC2-4200) crucial.com sells ram for you laptop 2gb will cost you about $50 +shipping.
Posted on May 19, 2008
You will need to remove the 2-512MB ram that are installed on your computer and buy 2-1GB sticks. There is no other way around this. Download CPU-Z program to find exact memory module needed before you buy the wrong one. Good luck.
Where is the memory slots for the Panasonic CF-T8. I know about the one on the back where it the other slot?
According to Panasonic's Toughbook CFT8
owners manual there is only one slot where
you can add extra RAM. The other memory
is "non-removable" and probably soldered
directly to the motherboard.
I double checked on the Kingston RAM Website:
Bank Schema: 1GB Standard:
[1GB] (Non-Removable)
or
3GB Standard:
or
2GB Standard:
[2GB] (Non-Removable)
or
3GB Standard:
Sorry to disappoint you but that is how they
made the CFT8 Toughbook.
If it is any consolation, the CFC1 and CFC2 both have
two (2) slots on the underside of the unit. Not the CFT8.
Good Luck,
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jan 17, 2014 | Panasonic Toughbook Cf-t8 Win7 Core2 Duo...
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
Can I add more RAM to my Averatec All-In=One A2?
Hey Nella Coffey
Unfortunately, more RAM cannot be installed due the limit of Slots available. However, you may be able to upgrade the current RAM modules and replace them. It appears it has 2048mb (2GB) of RAM which is possible split into two 1GB sticks. You "may" be able to upgrade to 4GB (split into two 2GB sticks). This is the current set up for the computer: 2048MB (4096MB max) SDRAM ' Memory Slots available for Upgrade: 0 ' Maximum RAM per available slot: 2048MB
Good Luck
Jul 29, 2012 | Averatec AllInOne A2 Desktop
What is the max ram speed my pc can take
According to some research, your desktop has 4 RAM slots available. The total maximum RAM your desktop can hold is 2GB (2048MB). Furthermore, each slot can hold a maximum of 1GB (1024) but cannot exceed the 2GB total.
This means you can theoretically install 2 x 1GB RAM DIMMS in 2 RAM slots or 4 x 512MB RAM DIMMS. Both will meet the desktops 2GB limitation.
The RAM specifications for your desktop are as follows:
RAM Limit: 2GB (2048MB) RAM Slot Type: SO-DIMM RAM Type: DDR1 (not DDR2 or DDR3) RAM Speed: PC3200/DDR400 ECC Type: Non-ECC
TIP: The RAM is DDR which means that while you can install them as singles (single-channel mode), the system will see a speed benefit from installing them as matched pairs (dual-channel mode).
Aug 14, 2010 | Sony VAIO VGC-RB34G PC Desktop
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
Can I upgrade memory to only one gb of memory or install 2 512 mb on a toshiba satellite m35x series
http://www.shopping.com/xPF-Toshiba-Toshiba-Satellite-Notebook-PC-M35X-S114
Looking at the specs, the max is 2gb for your Toshiba. According to this website, its only a 256mb ddr sdram. So my guess is you only have 1 slot for the ram. I'd go with a 2gb ram if you can afford it, 1gb just don't cut it in todays technology.
I believe its the PC2700 model, so find a 1gb or 2gb PC2700 @ 333mhz and you should be set.
Sep 09, 2009 | Toshiba Satellite M35X-S114 Notebook
Acer 9301AWSMi RAM memory extension
First, you would need the manual for that Acer 9301awsmi to fine out if the laptop can take 3 or 4gbs.
Second, see how many slots does the laptop have. This way you will how to place then. Like 2x2g or 1gb and 2gb,.etc.
May 01, 2009 | Acer Computers & Internet
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
HP Pavilion dv2000
This model laptop will not allow you to add a video card to it. The video card and all of its components are part of the Laptop motherboard already.
You can, however upgrade your memory from the 1GB up to a total of 2GB, but your current configuration is 2x512mb chips.
So right now you have 2 memory slots available but they are being used by the 2 512mb chips. You will have to remove them and replace them with 2 1gb chips. This can be fairly pricey.
Here is a link to your computer specs
http://h10010.www1.hp.com/wwpc/au/en/ho/WF06a/1090709-1116637-1116665-1116665-1116665-12435984.html
Apr 27, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Toshiba Satellite A135-S4527 Notebook Logo
179 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
