Alpine SPX-17 PRO Car Component System Logo
Posted on Sep 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought them used and would like a manual. SPX-177R componets
Anonymous
Level 2:
Scholar:
  • Expert 156 Answers
  • Posted on Sep 20, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
156
Questions
0
Helped
44468
Points
426
How to reset Yamaha spx1000 professional processor
To reinitialize the IS-SPX-1000 unit to its factory default settings:
1.
Unplug the unit from the power.
2.
Push the reset button and keep it pressed.
3.
Power up the IS-SPX-1000 unit.
4.
Wait with the reset button pressed for at least 8 seconds.
5.
Release the reset button.
6.
The IS-SPX-1000 unit will now boot in the factory default mode.
How to reset Yamaha spx1ooo professional processor
1.
2.
3.
4.
5.
6.
The IS-SPX-1000 unit will now boot in the factory default mode.v
Need the operators manual for a cobra SPX 5500 radar detector
easy to find.... google "cobra spx 5500 operators manual or follow this link...
http://www.cobra.com/sites/default/files/manuals/SPX5500_MANL.pdf
How to install salomon spx 45 bindings?
Your bindings have a "sliding yoke" system which means that a plate is screwed to the board using four screws and the the binding is mounted to the plate. Once this is done you can loosen the allen key and move the binding around on top of the plate to get your final placement.
1helpful
Installing hp laserjet 4100dtn over the network using tcp/ip addr
Hi admin30:
Here is some info for you.
EIO menu (networked printers)
The EIO (enhanced input/output) menu appears only when an EIO device is installed in an EIO slot
on the printer (such as an HP JetDirect print server). The items in the menu depend on the particular
accessory product installed. If the printer contains an HP JetDirect print server EIO card, you can
configure basic networking parameters using the EIO menu. These and other parameters can also
be configured through HP Web JetAdmin.
Table 27. EIO menu
Item Values Explanation
CFG NETWORK=NO NO
YES
Select whether or not you want to use
the HP JetDirect menu.
NO: Bypass the HP JetDirect menu.
YES: Use the HP JetDirect menu. You
must change this to YES each time you
want to use the menu.
Note
You must select CFG NETWORK=YES to
display the following items.
IPX/SPX=ON ON
OFF
Select whether the IPX/SPX protocol
stack (in Novell NetWare networks, for
example) is enabled (ON) or disabled
(OFF).
DLC/LLC=ON ON
OFF
Select whether the DLC/LLC protocol
stack is enabled (ON) or disabled (OFF).
TCP/IP=ON ON
OFF
Select whether the TCP/IP protocol
ATALK=ON ON
OFF
FG IPX/SPX=NO NO
YES
Select whether you want to use the IPX/
SPX menu and set IPX/SPX protocol
parameters.
NO: Bypass the IPX/SPX menu items.
YES: Use the IPX/SPX menu items.
In the IPX/SPX menu, you can specify
the frame-type parameter used on your
network.
The default is AUTO, to automatically set
and limit the frame type to the first one
detected.
For Ethernet cards, frame type
selections are EN_8023, EN_II,
EN_8022, EN_SNAP.
For Token Ring cards, frame type
selections include TR_8022, TR_SNAP.
In the IPX/SPX menu for Token Ring
cards, you can also specify NetWare
Source Routing parameters, which are
SRC RT=AUTO (default), OFF, SINGLE R, or
ALL RT.
CFG TCP/IP=NO NO
YES
TCP/IP menu and set TCP/IP protocol
parameters.
NO: Bypass the TCP/IP menu items.
YES: Use the TCP/IP menu items.
In the TCP/IP menu, you can specify
BOOTP=YES or DHCP=YES for TCP/IP
parameters to be automatically loaded
from a bootP or DHCP server when the
printer is turned on.
If you specify BOOTP=NO and DHCP=NO, you
can manually set the following TCP/IP
parameters from the control panel: each
byte of the IP address (IP), Subnet Mask
(SM), Syslog Server (LG), and Default
Gateway (GW). You can also manually
set the idle timeout period.
Print an HP JetDirect configuration page
to verify your settings. However, note that
the print server might overwrite selected
parameters with values that ensure
proper operation.
Table 27. EIO menu (continued)
Select whether the Apple EtherTalk
protocol stack is enabled (ON) or disabled
(OFF).
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
