Question about Whirlpool Washing Machines
Basket will not turn - Whirlpool Washing Machines
  • drcowick1955 May 19, 2008
    our whirlpool super estate washer, all of a sudden will not spin. any answers?
Try pulling out the center of the drum, this is usually where you put the fabric softener. Inside are little "elbow" type parts, they have teeth on them and they need to be replaced every few years as the teeth wear down the clothes won't get shimmy around in the drum.
Posted on May 19, 2008
Have a 2006 ktm 250 sxf seized rod to the crank got it changed reinstalled put motor back together now can not even kick it like somthing is stuck. Toke the clutch basket out, timing gear and water pump...
Your clutch basket is the link between the engine and transmission. Your kick starter rotates the clutch basket gear, which turns another gear at the engine crank. Remove either the basket or gear at the crank and see if the engine, and the transmission both turn. Sounds like the engine is stuck for some reason. At least you can cut the issue in half.
Aug 13, 2011 | 2006 KTM 250 SX-F
My washing no start and display view f34 Thanks
The F34 code normally only occurs when you are trying to run the CLEAN WASHER cycle. The washer should be completely empty of laundry when you are attempting to start this cycle. If the washer is empty and you are trying to run this clean washer cycle then you could have a friction problem with the spin basket that is causing the F34 code. Try turning the spin basket by hand with the washer empty and dry. The basket should turn relatively easily. If the basket will not spin easily you could have a problem with the bearing in the back of the outer tub or you could have an item stuck between the spin basket and the tub inside the washer.
May 04, 2011 | Washing Machines
I have a MieleG2142. One of the racks is not sliding smoothly which I believe I have narrowed down to one of the wheels in the rail guides not turning. How are the rail guides removed?
Hi dear.Try this.Pull the top basket towards you.Check on the side (if you can) back of the basket two of the wheels on top row should be on rail guide & third one just under the rail guide to support the basket.It should be even on both side of basket to run smoothly.If not pull the basket all the way towards you & lift up the basket you are holding.Basket will be free to come out of rail guide.(Please check,are the rail guides running in & out freely without basket?If not there are two plastic wheel inside of the each rail guide one or two of it must be damaged.That needs to be replaced.Please also check side wheels on the basket,they sould be freely turning.If not needs to be replaced.) If that did not work out,try to put back the basket even way to rail guide the way took it off.Contact Miele for assitants.Thanks.Goodluck.
Aug 07, 2010 | Miele G2142 24 in Builtin Dishwasher
My Kenmore Model 11027086604 washer will not drain and spin. The display blinks back and forth between F and 51. The instruction manual does not address this problem. What can I do?
does the basket spin freely?
could be something stuck between the basket
i can help you to take apart if you need instructions.
This would only if it is hard to turn by hand and you can hear something rubbing when you turn the basket.
F51 can be your rps sensor,board but more than likly "knock on wood" you have something stuck between the baskets very easy to check.
let me know
Jan 10, 2010 | Washing Machines
How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
F51 & F72 Codes
Basket Re-engagement Failure.
F then 72 flashes when the basket check routine fails to determine if the basket is re-engaged after being disengaged.
Is the basket floating? If yes, pump out water. See Long Drain.
Does basket turn freely? If not, determine cause of friction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jack Lalanne Power Juicer
I bought the juicer at a second-hand store in brand new condition however the crescent tool was missing. To remove the flat blade for cleaning, I use a pair of scissors spread far enough to fit the ends in both holes. Hold the basket still while turning the scissors counter-clockwise untill the flat blade detaches. Easy as that! I ordered the tool, but it hasn't arrived yet. Hope this helps!
Oct 11, 2008 | Jack Lalanne Power Juicer 250 Watts
How to Clean Pump Strainer basket
Turn the swimming pool pump off and wait for the water to drain from the strainer basket. You want to make sure that the pump is completely off before you proceed. Remove the screws or any items securing the lid of the strainer basket. Open the lid and pull out the strainer basket. Vacuum the strainer basket or scoop out any debris. You may want to run clear water through the basket to ensure you removed all debris. Feel toward the impeller and remove any clogs or obstructions preventing the impeller from working properly. Check the o-ring under the cover of the pump strainer housing. You may need to use a silicon lubricant to ensure a water-tight seal. Put the strainer basket back into the pump strainer housing and pour some water into the basket. Replace the lid and secure it in place. Turn the swimming pool pump on and check for proper pressure. If your pressure doesn't register, you may need to troubleshoot to find the problem.
Aug 27, 2008 | Belle Foret Accessories NBBS2-TB Tumbled...
How to Install Stainless Sink Baskets?
The stainless steel basin had a pair of big holes in the bottom, suitable for attaching strainer baskets or a garbage disposal. The basket comes with a black rubber gasket that seals underneath the basin, a thick paper washer, and a die-cast metal lock nut to clamp the basket onto the basin. There is also a smaller lock nut that connects the sink tail-piece (the first part of the drain system) to the basket. You should apply a bead of clear silicone to the rim of the opening. Also apply a small bead of silicone to the underside of the edge of the basket. olding the basket by the center, set it in the hole and gave it a slight turn to spread the silicone slightly. Down Under: apply a thin layer of pipe thread compound (a.k.a. pipe dope) to the larger diameter threads. Few plumbers use thread compound here, but I believe in lubricating threads whenever possible. There have been so many times that I needed to remove a basin lock nut, but was unable to because of the slight corrosion that inevitably forms there. Thread compound would prevent this problem. The metal lock nut, the rubber gasket and the paper washer were installed, turning by hand most of the way. The only practical way to tighten these huge lock nuts is to use a pair of 18" jumbo Channel-Lock pliers. To hold the basket from turning, use a pair of screwdrivers placed in an X-formation in the little holes. The lock nut must not be over-tightened, or the rubber gasket can be squeezed out of place, which could cause a leak.
Aug 27, 2008 | Belle Foret BF-NBBS2-CP Junior Basket...
F Code
the display is showing u something else look for the F then another letter or number. F is not a valid code
Sep 28, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
