Question about Sony Playstation 3 (PS3) Console
Dust makes scratches on ps3s?!
I just cleaned my ps3 after a long time and i found scratches all over th surface of it and i was wondering how to get them off and by the way if your wondering i have an 80gb ps3
  • 49 Answers
Yea i do too. you need to use a cloth that doesnt have products in it. there is no way to fix the scratches
Posted on May 20, 2008
Error 80010514 on Ps3
It could be 2 things.
1. You need to clean your lens.
2. Your lens is dead, and you would need to get it replaced.
Apr 18, 2014 | Sony Playstation 3 (PS3) Console
Tip
How to Fix a Scratched CD
Clean the disc. Even if a CD isn’t actually scratched or scuffed, dust, oil, and other surface contaminants can prevent it from playing properly. Thus cleaning the disc should always be your first move. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9503394424+5009222491+3607312525+8962074949+1162261192+0674921071+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Ads by Google
Fix It Scratch RemoverRepairs Scratches Like Magic! As Seen on TV. Guaranteed.
www.AsSeenOnTvAdvisor.com/FixIt
  • Run warm water over the damaged disc to remove dust.
  • If there is stubborn dirt or grease on the disc, gently rub it with your finger while you are washing it, and use a gentle detergent or liquid soap (with the water) or rubbing alcohol (in place of water). Any time you rub or wipe a CD, you should do so by starting at or near the center of the disc and rubbing straight outward toward the edge to prevent further scratching.
  • Shake the water off and let the disc air-dry (do not dry it with a towel or cloth, and don't sun-dry it either).
  • 2Try to play the disc. Many times a good cleaning is all that is needed. If, however, problems persist after cleaning, try to play the disc in a different CD player. Some players handle scratches better than others; computer CD drives and car stereos tend to be the best.
  • 3Burn a new disc. If you can get the CD to work in one CD player - especially your computer’s - but not in others, try burning a new disc. The CD burner on your computer may be able to read the CD well enough to produce a perfect copy. You may wish to try this even if the CD doesn’t play correctly on the computer.
  • 4Locate the scratch. Actually repairing the disc will be easier if you can figure out where the offending scratch is. Visually inspect the CD’s playing surface for scratches or scuffs. Scratches that run perpendicular to the CD’s spiral - that is, those that run generally from the center to the rim - may
  • on Mar 23, 2010 | Computers & Internet
    My ps3 shuts down exactly at the same point on one game every time, any ideas
    Does it do this on any other games? Sounds like a scratched disc, try cleaning the disk itself.
    Dec 18, 2012 | Sony Playstation 3 (PS3) Console
    It have dust all in it.so how do u clean it out
    First you need make sure its off and unplugged completely. Then move it to a clear surface. after that get the suction hose off your vacuum and put it to the vents on both sides and front of your play station 3 and suction th dust out.
    Mar 23, 2011 | Sony PlayStation 3 (120 GB) Black Console
    Ps3 scratched my game i think
    Go to CDFixers.com. They will professionally refinish your disc for $1.95 and it will look brand new. Good luck!
    May 02, 2010 | Sony Playstation 3 (PS3) Console
    How can i fix my PS3 disk read error
    The lens on the PS3 might have developed a fault which is preventing it from reading . Try cleaning the lens with a dvd disc cleaner first. Make sure the discs are not scratched or covered in dust
    Nov 02, 2009 | Sony Playstation 3 (PS3) Console
    Nikkor Lens Fix
    The fading (flare) you see could simply be a finger smudge or other stuff. One little scratch won't do it, you'd have to take sandpaper to the lens to see obvious flare.
    It's actually harder to scratch a modern lens than most people think. When it happens, it's usually during cleaning when a tiny piece of grit is on the surface and gets rubbed in by the cleaning cloth/lens tissue.
    So the first step in cleaning a lens surface is to be sure you remove all dust and dirt without rubbing. The lens cleaning kit you can find in any camera store is a start -- it contains a blower brush. With the lens surface to be cleaned facing down (so dust falls away), brush gently with the tips of the bristles to dislodge stuff. Then use the blower to blow it away. Repeat as needed.
    If you still see dust and dirt which seems to be stuck on the surface, take a piece of the lens tissue from the kit and put several drops of the cleaning solution on it, enough to get it pretty damp. (Always apply cleaning solution to the tissue or cloth, never drop directly on the lens surface.) Cover the lens surface with the damp tissue, pressing it into the corners, but do not slide the tissue across the surface. Just lift it away. Repeat with another section of tissue.
    Then take a full sheet, wad it lightly, and wet it. You are going to rub lightly, using a roll-up motion as you move the tissue so that dust/dirt is lifted away from the surface and fresh tissue is always coming in contact with the surface. Repeat as needed until there isn't any visible stuff.
    Final cleaning can be done with a fresh piece of tissue and a bit of mist from your breath. Mist the surface, and lightly polish with the tissue to remove any remaining cleaner residue.
    Dec 08, 2008 | Nikon Normal AF Nikkor 50mm f/1.8D...
    No game data found
    this soundsl ike the prob i just had, it is due to the last 2 updates causing laser to spin too fast, and burn out. only way to fix that i know, is by ringing sony, and they will happily send u out a replacement ps3 and a coupon via email for the post office to post ur console to them. they r still covering ps3s that have just ran out of warranty too. the service from sony was wonderful.
    Apr 23, 2008 | Sony Playstation 3 (PS3) Console
    Scratches
    I use diluted brasso/silvo to polish the surface & clean with water or wet cloth note this works for cds & dvds.
    Dec 07, 2006 | ViewSonic VX924 19" LCD Monitor
    Sony Playstation 3 (PS3) Console Logo
    27 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
