Question about GE 30 in. JGP336 Gas Cooktop
Automatic Eletric Ignition stopped working
The automatic ignition in my JGP336 gas cooktop stopped working. In the past if water etc poured into igniter orifice I have seen the specific igniter stop sparking till the igniter dried out. This time all 4 of them are out, seem like some part may need to be replaced. I haven't looked under the cooktop, not sure how to do that easily. Any ideas?
I accidentally posted the question on GE JGP636 forum so posting it here again.
  • 59 Answers
It's is normal for the ignitors not to work when wet, once they dry they should work. The best thing is to check the electric sending unit, they are a small white kind of square that goes on the switch, just lift the knobs and take the cover of the switches and you should see the sending units righ on the rod that hold the knobs, they have to small wires attached to them, It seems to me that thats were your problem is.
Do you hear the click clik when you put the knob on LITE??
Posted on Jul 25, 2008
I have a 30 in jgp336 gas cooktop that fails to ignite when it clicks what is wrong, it worked a few days ago and suddenly stopped working
usually the spark module is not put back together properly.
1 make sure the spark unit is clean
2 make sure the gas jet is pointing towards the sparker
3 make sure there is no aluminum foil or other metal near the sparker pulling the spark away from the gas
Jul 06, 2014 | GE 30 in. JGP336 Gas Cooktop
Gas cooktop never stop clicking 4 of them just keep starting without stop. I opened it and checked the wire, no problem.
Hi mikegou100,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 09, 2011 | GE 30 in. JGP336 Gas Cooktop
I am looking for ignation switch
Usually, the igniter is contained in the same switch ( control knob) as the gas flow. When you turn it on, you should hear a clicking noise. I've never seen one of these with a separate ignition system. Sorry if that's not the problem tokfm
Jan 11, 2011 | GE 30 in. JGP336 Gas Cooktop
Will not ignite. I have reset circuit breakers. what else to do?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 18, 2010 | GE 30 in. JGP336 Gas Cooktop
The electric starter on my cooktop started smoking (electrical fire). How do I replace it?
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Jul 17, 2010 | GE 30 in. JGP336 Gas Cooktop
All the igniters are clicking after cleaning - help!
heatman101
Apr 18, 2010 | GE 30 in. JGP336 Gas Cooktop
Igniter clicking when all four knobs in off position after water spill
It is possible that once the unit dries out the clicking will stop. If it doesn't, you will need to call someone to have the problem addressed. You will need a spark module and or an ignition switch(s).
Oct 28, 2008 | GE 30 in. JGP336 Gas Cooktop
Clicking sound whenever I turn on a burner
it would be the automatic ignition on it it may be earthing under the burners
Jun 14, 2007 | Jenn-Air JGC7536 Gas Cooktop
GE 30 in. JGP336 Gas Cooktop Logo
444 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
