Question about Hitachi 60UX58B 60" Rear Projection Television
POWER CORD CAME ATTACHED
I was moving and believe I pulled the power cord from the back of the tv I took off the panel and it was clear that the power cord was disattached from the circut board, how do i replace this or where do i re attach it too
  • 29 Answers
Can you send a pic? if not, where there is two lines, you need to strip the wire, and then solder it back.
Posted on Jun 18, 2008
No volume from cable
Hello!
First step: reset your cable box by unplugging of the power supply or unplug power cord of the box. If that's an old fashion big gray one or black one with additional power outlet for TV set, there is a power cord goes into. Unplug it, then plug it back in within 1 minute. not the TV itself, but the cable box's power cord. This will reset it. If you have more modern one or small one for non HD TVs, they have external power adapter, which plugs into those boxes.
Pull that plug out for a minute, then plug it back into. That should take care of your sound issue. Known problem.
Good luck,
Let me know if that took care of your issue.
thanks,
Alex.
Dec 11, 2011 | Toshiba 19SLV411U 19 in. LCD TV/DVD Combo
Red vertical line on the screen due to external shock
This is most likely caused by the cable on the T-CON board being bent out of place by the shock.
If you know how to work on electronics or have a friend with knowledge/skill you can fix it.
DO THIS ONLY IF YOU KNOW HOW TO WORK WITH ELECTRONIC EQUIPMENT.
REMOVE THE PLUG FROM THE WALL. REMOVE INPUT signal cable from set.
REMOVE THE POWER CABLE FROM THE SET.
>Lay the set down on a flat cloth covered surface.
>Remove the back cover.
>Remove the shield covering T-CON board. This small board is located in the center near the top.
>Move the cable(s) connected to the T-CON around.
> Set the tv upright and make sure it is stable.
DO NOT TOUCH ANYTHING ON THE BACK
ATTACH INPUT SIGNAL cable to set.
ATTACH THE POWER CORD TO THE SET.
PLUG THE POWER CORD INTO THE WALL.
>Use the remote to turn the set on. If the vertical lines are gone, THEN TURN the set OFF.
REMOVE THE POWER CORD FROM THE SET. Remove signal cable.
> Lay tv back down on table.
CAREFULLY REPLACE THE SHIELD over the T-CON.
Replace the back cover etc.
Now you can reconnect the input cable and power cord.
SOMETIMES THE IMAGES can get worst and you have to repeat moving the cable around. In the worst case you can dis-connect and re-connect the flat cable WITH THE SET UNPLUGGED.
I believe the T-CON may sometimes be called LVDS and look similar to;
Feb 15, 2011 | Sharp Aquos LC52XD1E 52 in. HDTV-Ready LCD...
The cord to my tv was pulled out of the electric socket by accident, like the electric going of and on..now my rgb signal wont work....
The question is not very clear but I think I understand. Unplug everything from power for ten minutes. Plug everything back in and power on one by one.
Jan 25, 2011 | Vizio 42 in. LCD TV
The power cord was crushed and no power is getting to the tv. Is the plug able to be replaced as this has happened below the splitter???or whatever the thing is on the cord. thanks Shelley
If the power cord comes off the television you can replace it with a standard power cord. You have to tell the Radioshack employee how many volts and hertz. That should be on the back of the television. If the power cord does not come off the television you can find someone perhaps a tv repair guy that can attach another power cord to the one on the television. My dad actually did that when his older television would no longer power on. He took the bottom part of a power cord from a fan that was no longer working and attached it to the television's power cord. It has been working like a charm ever since for years.
Sep 28, 2010 | Televison & Video
Hoover Windtunnel Tseries cord pulled out too
In the case of where you have decided to "fix" it yourself the best thing is to make small drawings of what goes where as you take things apart. Lay out a white towel and put all the parts on it in the order you removed them. To keep from loosing screws you can screw them back in their holes you took them out of, or lay them in order next to the part you took off. Sometimes there may be longer screws. On your drawings indicate where they go. You don't have to be an artist, just as long as you can understand what you've drawn. As far as the switch is concerned it's either a safety feature or there is a wire pulled part way out and is pushed or pulled back into place when you lean the handle back. Now, understand that there are flat metal "clock" springs that are wound up tight on the part the end is attached to. Whatever you do pay close attention to what is going on just as you begin to open the housing up that holds the cord. If the clock spring is attached to something that may come loose as you pull it apart, it's liable to come off of the winding mechanism and completely unwind suddenly. I've had this happen before. And you never know how many times to wind it up in order for it to be able to pull the cord back in the housing quickly like it did when it was working.
Mar 08, 2010 | Vacuums
I had a paper jam and I took the back off and this
Step one: Remove any loose paper
Remove all loose paper from the input and output trays.
1. Turn off the product.
2. Unplug the power cord from the back of the product.
3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
6. Carefully remove any jammed paper.
7. Close the cover.
8. Reinsert the rear-access panel or the duplexer into the product.
9. Plug the power cord back into the product.
10. Turn on the product.
Step three: Open the top cover and clear the jam
3. Open the carriage access door. The carriage moves to the right side of the product.
4. Gently pull the paper out of the rollers.
5. After clearing the jam, close the carriage door.
6. Plug the power cord back into the product.
7. Try printing a document.
· If the issue is resolved, do not continue troubleshooting.
· If the issue continues, proceed to the next step.
Step four: Clear the jam from paper tray 1
1. Remove all paper from the output tray.
2. Turn off the product.
3. Unplug the power cord from the back of the product.
4. Lift the output tray and then check for jammed paper in input tray 1.
Use these steps to remove any jammed paper.
a. Raise the output tray.
b. Grasp the jammed paper and pull it out of the product, toward you.
c. Lower the output tray.
5. Plug the power cord back into the product.
6. Try printing a document.
· If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
· If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
Step five: Clear the jam from paper tray 2
4. Lift the product off tray 2.
5. Remove the jammed paper from the bottom of the product or from tray 2.
6. Reposition the product on top of tray 2.
7. Plug the power cord back into the product.
8. Try printing a document.
3. Remove the ADF input tray and open the ADF cover.
4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
6. Check the ADF paper path for jammed paper.
7. Check for jammed paper where paper enters the ADF paper cleanout.
o If the paper comes out with gentle pulling, proceed to step 9.
o If the paper does not come out with gentle pulling, follow these instructions.
1. Open the ADF, and then use both hands to gently loosen the paper.
2. When the paper is free, gently pull it out.
3. Close the ADF.
8. Lower the green lever.
Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
9. Replace the ADF input tray.
10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
o Make sure that the ADF frame is secure and attached correctly.
o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
1 - Stack stopper
2 - Two-catch
11. Plug the power cord back into the product.
12. Turn on the product.
13. Try printing a document.
Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Panasonic pt-53wX42, power wont stay on. Turn on, no picture then it will turn off by itself after 5 seconds. The red power button will flash on and off until I unplug unit and start the whole process...
I'm no expert, but I'd start by taking a "VERY GOOD LOOK" w/magnifing glass if possible , @ UR Wall Outlet Power Cord. Change to different wall outlet. Ur Power Cord "should" just pull right out of the back of your TV. If nothing in those places, then take off back panel (or part where power cord plugs into TV & AGAIN inspect area around where power cord attached for, yeah, that's right, the dreaded black area around plug-in area. Maybe it's just a bent prong. Any other funny things going on that U didn't mention here? Good Luck Leonard aka quikstudy@cox.net
Jul 23, 2008 | Televison & Video
Power cord pulled out
i have just pulled the back by removing 5 or 6 screws. you can see the circuit board, and the power cord is soldered directly into the board. two wires,one black and one white. near the left back corner--- from the back. you can re solder it.
Mar 27, 2007 | Sanyo DS25390 TV
Televison & Video Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
