SATA Connector HP sent me to Best Buy to get the part needed to connect my 2.5" Drive to the open port on my HP9700z. I'm in Iraq and find it hard to run to the store at the moment. It's a bridge to connect my HD to my motherboard. Can you find me the piece I need and how much will it cost?
    President:
  • 2,351 Answers
Hello united4fun, the link I'm adding here will give you an idea of what you're looking for. You can also buy the cable from this web site if you wish.
1m Serial ATA to External Serial ATA Cable.
http://www.cablestogo.com/product.asp?cat%5Fid=927&sku=10230
& here.
http://www.satasite.com/sata-cables-external.htm
At this next link you can click the drop-down menu ( Select country/Region ) nearest to you for faster service.
http://www.alibaba.com/trade/search?Type=&year=&month=&location=&keyword=&SearchText=External+Serial+ATA+Cable&Country=&srchLocation=&srchYearMonth=&IndexArea=product_en&CatId=0
This link above does carry the item, Serial ATA to External Serial ATA Cable.
Enjoy!
Have more questions? Feel free to post them here or click the Ask Me button under my user ID.
Mike
Posted on May 19, 2008
  • Mike Peluso
    Mike Peluso May 19, 2008
    Please vote fix, if you find this helpful.
Add a hard drive to mcp61pm-hm motherboard
So it's an HP Motherboard is that right?
and it has 1 IDE/PATA Port and 4 SATA ports?
(Motherboard spec available here: http://j.gs/13861611/motherboard-specs )
-Charles
Jul 02, 2016 | Computers & Internet
I have a Dell Inspiron 8600 which is running windows xp pro. I have 2 Gigs of memory, the computer runs ok, but I'm receiving info from scans that my HDD Pata is about to go,I'd like to change
Well, you will want to open up the side of your computer and see if there are SATA ports on the motherboard. They look like this:
Though they may not be blue.
If there are SATA ports on your board, you are in good shape. Just buy any SATA hard drive (SATA2 and SATA3 are backwards compatible) and connect it with the SATA connector and a SATA power connector from the power supply. Don't be afraid, these can only plug in one way without forcing them and only SATA plugs will fit.
After that, there are a variety of drive cloning programs you can use to clone your current hard drive onto another so that you don't lose anything.
If you don't have SATA plugs on your motherboard, it is easily remedied. You can buy a PCI SATA card for quite a reasonable price like this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816124024
You will also probably need a small adapter like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812189121
To convert a molex plug into a SATA power plug.
After you plug in the card and the new hard drive, run the driver CD for the SATA add-in card and then run a cloning program.
Oct 25, 2012 | Dell Inspiron 8600 Notebook
I have a HP pavilion a1700n and the dvd quit working. I bought a hp dvd/cd writer 1270i. This unit has SATA connection. I noticed that my a1700n has an unused SATA connector and there are three unused...
A SATA hard drive needs to be pugged into a SATA port on the motherboard. They're the "L" shaped ports. They look like this: moondogwst75_2.jpg
The little blue ports. The hard drive should have come with the appropriate cable. Other than that, just plug in a SATA power connector to your hard drive and you should be golden. Hope this helps!
Aug 27, 2011 | HP Pavilion a1700n PC Desktop
How 2 install a triple format sata internal drive in a gateway desk top
check for a open sata port on your computer. if there is one connect the hard drive with a SATA cable to the sata port on the motherboard.
connect the sata power to the hard drive or a molex to the hard drive if you do not have one. do not connect sata and molex to the hard drive together. if you don't have a molex connect you will need a molex to sata power adapter.
after connecting the hard drive to your pc. turn it on. in windows xp it will auto detect the hard drive and may prompt you to format the hard drive.
Mar 28, 2011 | Computers & Internet
My HP dv200 Laptop video card died now I am trying to recover the data from my HDD [fujitsu MHW2160BH] the problem is that the HDD will not connect in a SATA hard drive enclosure. The connectors do not...
if you look at the connector on the harddrive it is not a sata connector pull tht connector piece off and underneath it is the sata connectors you are looking for.
Jan 05, 2011 | Fujitsu MHW2160BH 160 GB SATA Hard Drive
How to install 2 t hard drive in computer compaq
A 2Tb hard disk will be a SATA hard drive. If your PC Desktop does not have a SATA disk controller then your have a couple of options.
1. Insert a SATA controller card into the PCI expansion slot, mount the SATA hard drive inside the PC case and then connect the SATA hard drive to the controller (you will also need a 4 pin power to SATA adapter cable) and install the SATA controller driver.
2. The other option (and the easiest) is to purchase an external USB 2Tb hard drive. All you need to do is, plug it into the USB port of your computer and it will see it as an external storage device.
Oct 22, 2010 | Computers & Internet
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
Sata drive will not fit
This is clear that your laptop doesnt support SATA and will support only to the previously used type of HDD..
Thankyou
Jun 17, 2008 | HP Pavilion dv9000z Notebook
It looks like there's an empty drive bay in my Gateway GM5446E Core-2 Duo desktop computer. I happen to have a spare Western Digital 500 GB Caviar drive. Can I use 2 hard drives in this machine?
You should be able to - but just as important as an open bay, is a connection to the motherboard and power is necessary. It would also matter which type of drive you have, IDE or SATA. If Sata, and the computer has Sata power, it should be a simple matter to add a Sata cable to an open connector on the motherboard. If IDE, you'd either need to have an open IDE port on the motherboard, or an open connection on an IDE cable. If there is no open port, but an open connection, you'd just have to set the drive to be the Slave, and it should otherwise work fine.
Realize you will probably need to partition and format the hard drive for the system to be able to utilize it.
Feb 17, 2008 | Computers & Internet
I need to add a hard drive to my HP a1220n Pavilion for Photoshop and other Graphic programs. How can I do it if there is no available slot? Please help.
A desktop PC would normally have capacity for 4 IDE devices such as 1 CD/DVD, 3 HDs or any combination limited to a total of 4. Additionally, most current PCs have 2 SATA connection points. If for some reason all are occupied and hence your post "no available slot", you may want to consider using an external storage device attached via any USB port of your PC.
Hope this be of some help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | HP Pavilion a1220n (A1220NED904AA) PC...
Computers & Internet Logo
385 people viewed this question
David Payne
David Payne
