Question about Danby DPAC8399 Air Conditioner
A PART IS BROKEN
HI
THE PART THAT CONECT THE EXTERNAL TANK TO THE AIRCONDITIONER BROKEN, WHICH IS THE WHITE PIECE THAT SCREWEND IN THE TANK AND IT CONNECT TO THE SILVER PIECE IN THE AIRCONDITION. WITH OUT IT I CAN NOT USE THE EXTERNAL TANK
THANKS
  • Anonymous May 26, 2008
    the piece from the bottle at the back of the unit is missing., the small connnecting clip.
  • 770 Answers
Check their web site or go to home depot with the tank they should have a fitting that will work for you
Posted on May 20, 2008
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
I have a dandy portable a/c and it has an external water tank on the back and the tank is removeable for draining water out my prob lem is the piece that attaches the external tank to the machine ( on the...
The best place to start is the manufacturer, Danby. For parts not covered under warranty call
800-496-6049. In your unit is still under warranty call 800-263-2629.
Hope this helped you. Please let me know. Thanks.
Jun 08, 2011 | Danby DPAC8020 Air Conditioner
My windows on the driver side will not roll down. I have checked the fuses and all are fine. The driver and left passenger door window switches have stopped working. How do I fix this?
open the drivers door and pull back the boot that goes between door and body. all the wires run through it. you will find one or two wires in there that have broken in half. get a piece of wire the same gauge as the broken ones about 4 inches will do.put a crimp but connector on each end of the piece of wire then stripe and conect to each end of broken wire.loop the extra wire so it lays flat the loop keeps it from breaking again
Mar 23, 2010 | 1997 Jeep Grand Cherokee
Received no instruction manual with tank and broken plastic nut
The piece you are referring to is the water inlet to the tank. go to your local hardware store and buy a new one. It installs on the bottom of the tank. Use an adjustable wrench. Nothing on the toilet needs to be extremely tight. In fact after you put the was ring on the bottom of the toilet. Drop in the closet flange bolts in the closet flange (brass bolts with a t on one end) do not tighten them extremely tight the toilet will break.
Mar 19, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
Reset button triping on bradford white electric water heater
replace upper thermostat, and hi temp limit, usually made in one piece, also make sure the new stat is pushed up tight to the tank when you install it.
Dec 05, 2009 | RTO Bradford White M-1-20U6SS 19 Gallon...
Leaking under the rim of the toilet
Sound like what you are looking at is a corroded bolt that holds the tank onto the bowl. Remove and replace bolt and gasket with new part.
Jun 07, 2009 | Mansfield Plumbing Products Mansfield...
Broken external hard drive
if the broken piece is internal and rattling around, it is most likely terminal and you need to replace the hard drive, if it is an external part or a connector you may try a computer shop to see if it can be repaired, but more than likely that will cost more than replacing the drive, but they may be able to recover any data that is on it
Good Luck
Feb 22, 2009 | Maxtor Computers & Internet
WD External HDD Drivers For Win 98
I dont think the Win 98 has a plug and play option. You may need to search for device drivers for your external HDD which may not be easily available
Feb 01, 2009 | Computers & Internet
Data transfer
u either plug an external monitor or u remove the hard drive from the broken system then get an external hard disk case . conect it then to yr usb port on the mac system so yu can transfer yr data.
hope this helps
thank u
May 26, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Danby DPAC8399 Air Conditioner Logo
172 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
