Question about Linksys Wireless-G WRT54G Router
I want to reconfigure my router for verizon - Linksys Wireless-G WRT54G Router
  • Anthony de Araujo May 11, 2010
    Unless your router was configured very strangely, you should be able to use it with Verizon DSL (if that's what you're talking about) without any modifications.
    Let me know what problem specifically you are having to make it work with Verizon.
    Scholar:
  • 176 Answers
Just reset the the reset button of the the linksys router. At the back the of the router there is small hole and also the sign or word reset . Press the reset at least 12 second using a a pen tip and turn off the router. When you turn on again the router the configuration is set to the default setup. Try to connect now to the Verizon DSL if not working try to run the the web base setup by type in the internet explorer the router IP 192.168.1.1 then set or follow the instruction there.
Posted on May 19, 2008
Will the verizon gt704 w6 work with at&t service? how do I reconfigure it to do this?
Theoretically yes. It would be under the advanced settings- you would have to change the VC configuration to the settings that AT&T run on. However, I am not familiar with AT&T's policies concerning third party modems. As for Verizon, I know they only provide passive support- and do NOT send out technicians for signal trouble if you are using a non-supported modem. I suspect AT&T is the same way.
Oct 06, 2010 | Actiontec GT704WG Wireless Router...
I have a WGT624 router. I have had verizon internet for about 2 months. Recently, I could not get on the internet using wireless but could when just using the modem. I have unplugged the router and then...
either you need to reconfigure the router for the wireless configuration or setup the router for PPPoE connection. if you have internet directly to the modem contact your router manufacturer if not then you need to contact your ISP and ask if you need to setup the route rwith PPPoE connection and get the user/password
Sep 07, 2009 | NetGear WGT624 Wireless Router
Need help with wireless router and wireless verison card.
You need to bridge your modem first before you can use your netgear wireless router. You can reconfigure your netgear without bridging your modem and it will work, but the connection will not be as stable. You'll only need your Verizon password and username if your connection type is PPPoE. If your connection is DHCP, you don't need your username and password anymore, but you may have to ensure that your connection type inside the netgear router is set for DHCP as well. If you're a PPPoE, then you don't have to worry, even if you don't know your username and password, you can give Verizon a call and they will reset your password and give you your username after you've verified your information with them so you don't have to worry about anything. Whatever issue it is, they can help you with it. I suggest you have them bridge your modem first before using your netgear. If I know the brand and model number of your modem with verizon I can definitely give you instructions here on how to bridge your modem properly. Just let me know.
May 24, 2009 | Sony Playstation 3 (PS3) Console
Can not get netgear to go on line
give a try by resetting your router n reconfigure it,that might fix your problem
Dec 13, 2008 | NetGear WGT624 Wireless Router
Constant disconnect on both laptop and desk top
  • If you bypass the router and connects your computer directly to the your DSL modem, do you have a stable Internet connection in your computer?
  • If you do, you may reset and reconfigure your Belkin router.
  • You may also do a firmware upgrade on your router.
Hope this helps!
Nov 23, 2008 | Belkin Computers & Internet
Reconfig 327w to work with Hawaiian Telecom DSL
try this launch IE go to tools internet options, connections tab, remove all the dialup.
this will fix the verizon connection problem.
Oct 09, 2008 | Westell Wirespeed VersaLink...
Wireless-G Linksys Router No Signal with Verizon Modem
The first thing I would recommend is to reset the router to its factory defaults. Then reconfigure it according to your Verizon settings.
There are a number of things you need to set, in order for the router to be able to talk to Verizon correctly. These things such as dns name servers, the ip address you connect to (whether it is static or dynamic), and things of this nature. They should have given you all of this information, and if they did not you will need to contact them first or you will not be successful in connecting.
To be more specific regarding the error message, I need to know the specific model you have as well as the version of the software.
If you need additional help just post another question here and it will notify me that you have.
Jun 19, 2008 | Linksys Wireless-G WRT54G Router
Problem accessing router
You can try the link below and see if you can get the default password..
http://www.routerpasswords.com/
Jan 04, 2008 | Westell Wirespeed VersaLink...
WAN settings
The WAN settings should be configured by Verizon personnel only. If you reset the VDI-604 or VDI-624 to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
WAN settings
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Linksys Wireless-G WRT54G Router Logo
135 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
