dont tell you much,..i loaded it put the same old problem no camera..now what ..thanksdont tell you much,..i loaded it put the same old problem no camera..now what ..thanks
alL i no is its called acer orbicam came with my acer aspire 5610Z BUILT RITE IN IT alL i no is its called acer orbicam came with my acer aspire 5610Z BUILT RITE IN IT
thanks the orbcam came on just took awhile ..thanks the infro was very helpfulthanks the orbcam came on just took awhile ..thanks the infro was very helpful
yes i fixed it....thanks now how do you i adjust the lighting on it its kind of dark yes i fixed it....thanks now how do you i adjust the lighting on it its kind of dark
AnonymousJul 07, 2008
icant open my web cam aspire 5610 error messege icant open my web cam aspire 5610 error messege
I reformatted my computer and now i cant open the webcam its almost like software dont excist on my comp its acer 5610Z build in web camI reformatted my computer and now i cant open the webcam its almost like software dont excist on my comp its acer 5610Z build in web cam
AnonymousJan 02, 2009
i can instal web cam i can instal web cam
You can't post conmments that contain an email address.
Did you download the application or the driver or both. Which Orbicam do you have Bison, Logitech or Suyin? Have you uninstalled the webcam, rebooted and then direct windows where to look for the driver and application?
find the program for the cam in start- program there to adjust,after done if you open program like skype,you still need to switch on webcam in after you call.
Install properly the provided web cam software to run web cam properly. This are some problems due to unstable or not completely install on it. Use that Utility Recovery Disk. Good luck!
sometimes when you save photoes in your picture folder the webcam stops working just simply move all pictures out of the picture folder unless they have to do with the webcam software worked for me
Your questions are less about an issue and more about just how to use the machine. persavere and keep trying different things. Eventually good things will happen. Its how we all had to learn. As for accessing the camera go to start and search the word cam. vistas usually pretty good and will find it for you
