Question about Kicker CVR12 Car Subwoofer
My subwoofer stops when volume is increased
AMPLIFIER MODEL:ALPINE PDX-4.150(RMS 600 WATTS)
SUBWOOFER:ALPINE SWS-1043D(RMS 300 WATTS)
SUBWOOFER IS GIVEN FULL RMS 300 WATTS.
WHEN VOLUME IS INCREASED TO MORE THAN 23 (MAX35,SONY EXPLODE CAR STEREO) THE SUBWOOFER STOPS.
GAIN & OTHER ADJUSTMENTS ARE ALREADY TESTED.
KINDLY ADVISE.
bikram
  • true blue31 May 01, 2009
    i have the some problem i think is the power supply or the inputs
Have u check the radio out do u have an eq
Posted on May 01, 2009
  • wyatt201086 Mar 20, 2012
    If i mess with the eq it makes it even worse the volume has to be lower for the sub to kick back on. I have a Sony explode 1100w amp, 12in. Pioneer sub, and my stereo is a pioneer. Help
I have this subwoofer eclipse 800 watts peak, 8 ohms , and i would like to know if the alpine pdx m6 can deliver 600 watts rms at 8 ohms too, o just at 4 o 2 ohms, i will appreciate your help.
No. It is optimized to deliver 600 watts onto either 4 or 2 ohm loads but will decrease to 300 watts into 8 ohms. However that equates to only about a 3dB difference in output level from the sub. 3dB is the smallest amount of volume difference the human ear can pick up. A doubling of volume requires a9dB increase which requires a tripling of input power.
Aug 09, 2016 | Alpine Car Audio & Video
Need box specs for Alpine dvc type r 2ohm 12"
  • frequency response: 24-200 Hz
  • power handling: 300-600 watts RMS (300 watts per coil)
  • peak power: 1,800 watts
  • sensitivity: 85 dB
  • top-mount depth: 6-3/8"
  • sealed box volume: 0.65-1.25 cu. ft.
  • ported box volume: 1.0-2.0 cu. ft.
  • Crutch field audio has a DIY section on box building ;)
Oct 20, 2014 | Car Audio & Video
I have the MRP-M1000 amp. I want to hook up 2 alpine subs to this amp. Which alpine subs would be the best for this amp? Please be specific with ohms and watts.
Your best bet will be to wire 2 subs in parallel to the amp. Each sub should be rated for at least 300 watts rms at 4 ohms. This will give you a total impedance of 2 ohms, and your amp will put out 600 watts rms at that impedance. That way, each sub will receive 300 wats rms. I would not recommend wiring subs in parallel, as you will need two 1 ohm subs at 300 watts rms, which are harder to find and will be more expensive. A parallel circuit is the most efficient way to do it.
Feb 23, 2011 | Alpine MRP-M1000 Car Audio Amplifier
Subwoofer and amplifier wattage problem
No it will sound good if you can put an amplifier with 500 watts rms it will sound better
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Spec for type r 10
  • 10" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 26-600 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • sensitivity: 83 dB
  • top-mount depth: 6-7/8"
  • sealed box volume: 0.5-0.8
  • ported box volume: 0.6-1.3
Nov 20, 2009 | Alpine Car Audio & Video
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine pdx 1.600keeps cutting out
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Installing two amps
No, thats what you don't what to do. Even if you have 2 matching amps you don't do that. Every amp puts out different, and for 2 subs, you want to play at the the same time. If your only running 2 10's, I personal would just run the alpine (it's a mono amp made especially for subs) thats plenty for what you have. make sure you bridge them to get the full response. And your other amp i would use for your highs or mids, but run it @ stereo , which is 300 w @ 4 ohms. (Note: 600w @ 2ohms would be bridged and would play in Mono)
Building Competition stereo's is a big hobby of mine.
May 04, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Alpine PDX-4.100 3ch operation
use channel 1 and 2 as normal, use the positive from channel 3 and the negative for channel 4 as mono 1ch, your bridged output on the mono chan should be around 200watts at 4ohms.
Nov 25, 2007 | Alpine PDX-4.100 Car Audio Amplifier
Kicker CVR12 Car Subwoofer Logo
151 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
