Question about Kenmore 63942 Dryer
Kenmore 80 series stop turning
The dryer works when it's starts cold but stops after heating up. I did smell a slight burning and the drum inside seemed a little loose.
  • 481 Answers
Most likely a bad motor; expensive.
Posted on Jun 28, 2008
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety...
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Apr 08, 2011 | Dryers
I have a Kenmore Electric Series 80 Dryer that the drum inside won't turn but it heats up and smells hot like something is burning. I can however turn it manually.
Remove the top and the front panel to remove the drum after you purchase a belt and teh idler pulley that Sears selles for your dryer. The pulley's bearing has froze up causing the belt to burn up and falling off
Jan 22, 2011 | Kenmore Dryers
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore 80 series quit heating after burning smell..
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.ff8b5e7.jpg
Dec 22, 2008 | Dryers
Kenmore 80 series dryer
check to make sure you have 220 volts to dryer. if so check element for continuity make sure power is off
Dec 08, 2007 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
142 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
