Question about Microsoft Xbox 360 Console
Running two xbox live 360
Hi
my boys each have a white xbox live 360.
I have comcast service running into a cable mode and into a 8 port cable/dsl router that are are wired teach xbox The Linksys router is model BEFSR81. I contacted Linksis to unrestrict the NAT from strict to open
Everything seemed to run fine but recently when one of my sons goes onto play, he is able to identify his players and begin a game. when my other son turns his box on, it seaches for players, identifies them them restarts the seach for players again and essentially does not allow him to begin a game. Whoever turns their Xbox on fr a game first I gues is the winner. The router is new and modem and wiring all check out fine
On the network page of the Xbox, all iems pass when a test is run.
many thanks Gregg
  • target09 May 19, 2008
    thanks, I checks router setting and the DHCP is enabled. I did a hard reset a week ago and duplicated the settings.
    Unfortunately the second ip address is $
    Thanjs
    Brigadier General:
  • 6,966 Answers
A couple of things you can try:
1. do a full hard reset of the router. This is done by pressing on a small recess button at the rear of the LinkSys. Of course doing this will revert the unit back to factory default. Pls have all configurations and settings backed up or written down;
2. Try using static IP adds at each XBox (if able);
3. verify that the DHCP feature is enable in the LinkSys.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 19, 2008
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
A router shares your internet connection with local computers and devices on your local area network. Microsoft's xbox live requires a connection to your IP address on a certain port. This will be a problem when using 2 xboxes so what you would need to do is contact your Internet Service Provider, explain that you are using a router and require an additional Static IP Address.
Once they provide you the details for this, you can manually set up one of the xboxes with the static details your isp has given you.
This should stop the 2 xbox conflicting over connecting to the internet, as they will be running on seperate ip addresses.
Hope this helps.
How to connect Xbox 360 to modem
Hi Nacee..
Hope your r good there!
Anyways...First thing you should do is turn off your computer, cable or DSL modem and XBOX 360. Then you should hook an Ethernet cable from the cable modem to the Ethernet port on the back of your XBOX 360. Then power up your cable mode and then power up your XBOX 360.
BR
Alia
from
Twindi-online computer store
Feb 13, 2011 | Computers & Internet
It says it cant connect to xbox live even though i have a ethernet cable hooked up to my lab top running to the back of my xbox 360.
Depending upon your Internet setup connecting your XBox cannot give you Internet access to XBox Live.
For a least complicated method, you need to connect the XBox to a DSL or cable modem that has Internet connection via your Internet Service Provider.
How is your laptop connected to the Internet?
This information would assist me to help you.
Jan 25, 2011 | Office Equipment & Supplies
I just got this dynex 4 port ethernet hub and i have comcast wired internet . and i want to hook it up to my xbox 360 and my computer but , it wont let me . when i try to get xbox live it says network...
You need a router not a hub or a switch. with the help of the router you can share the comcast cable internet on multiple devices. A hub or a switch can not do this.
Get it replaced with a router. You can buy Linksys or Netgear router.
Rashish
Aug 17, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
How do i configure a wireless adapter for xbox live
To use the Xbox 360 Wireless Networking Adapter with Xbox Live, you must have a high-speed Internet connection (cable or DSL).
Your wireless networking adapter is designed to attach directly to the back of your Xbox 360™ console.
Refer this article http://www.xbox.com/hi-IN/support/xbox360hardware/system_setup/setup_accessories/wirelessnetworkadapter.htm#Attach
Jun 01, 2010 | Microsoft Wireless Network Adapter Xbox...
1008d wanting to know what to plug in
The D-Link DES-1008d is an unmanaged switch that does not need any configuration to work. You just need to plug in your device (PC/Xbox/Laptop) into one of the ports of the switch, using an ethernet patch cord, and it would start communicating with it. I think your xbox 360 already includes a patch cable in the box. You also need to connect the 1008d to your DSL/Cable/whatever modem, using a similar ethernet patch cord, in order to get online.
This is all that you need to do as far as your 1008d is concerned.
Mar 31, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Have one ethernet for computer want to use xbox live so i take out the ethernet from computer and put it in xbox unplug wait plug back in turn still will not connect red x for modem
You should get a cable/dsl router/switch or wireless cable/dsl router/switch and put it between your Modem and network nodes (IE your computer and xbox 360)
So it is modem to router wan port
Xbox 360 to router lan port
Computer to router lan port
You can purchase one cheaply at best buy
look at this link
http://www.bestbuy.com/site/olspage.jsp?skuId=8741365&type=product&id=1202648529130
Jul 29, 2009 | Microsoft Xbox 360 Console
Gigafast ethernet won't let my Xbox connect to live
You might open this ports to the Gigafast Ethernet router :
TCP 80, 3074 and 53
UDP 88, 3074 and 53
Note: You'll needing to open these ports to the virtual server or port forwarding under advance settings of the router.
Mar 06, 2009 | GigaFast Ethernet Gigafast 10/100, 8-Port,...
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
Online
Yes and No, you can use the phone line for internet access to your xbox, but unfortunatelly, X-Box Live requires a high speed modem, or DSL Service, like verizon, or Comcast.
Feb 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
73 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
