Question about SanDisk Sansa m240 MP3 Player
Starts over I use my m240 to listen to audio books that I download from my library. Unfortunately, I do not get to sit for an hour, and need to pause. When I pause, it goes into shut down mode. When I power back on, it starts at the beginning. Not a big deal, but it also won't let me scan forward or back to the correct spot. I would be happy to either know how to get it to pick up where it left off, or to be able to scan back to the right place.... Any suggestions? Also, where can I get an instruction manual for it. I bought it refurbed from Thanks! Kelly
  • 8,596 Answers
Manual is on Sandisk website
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
How do I bookmark or save my place in an audio file
Try and press pause before you shut the player off.
Mar 30, 2010 | Coby MP-610 MP3 Player
Fast forwarding for listening to books
I use a Creative Zen V Plus, but have a similar problem.
First, an explanation: the issue is probably with the timecode in the audio track. This can happen when the audio file is created on a computer. The audiobook was likely "ripped" to a file from the original audiobook CD, and your player may not like the format the file is in. The best solution in this case is to recreate the audio files yourself. First remove all of the files from your Sansa for that particular book. Then use CD-burning software on your computer to create an audio CD (not a data CD!) from the files you got from the library. Finally, use the software that came with your Sansa to transfer the audio CD back to your Sansa. This way you know you are getting a correct format on your player.
If you have an additional issue (like me) where the tracks are too long and go back to the beginning every time you turn your player off, you may have to use an audio editor such as Audacity to chop the long tracks up into smaller tracks, but this is quite time consuming. It is best to acquire audiobooks in smaller tracks in the first place. This is the problem I have been faced with while using to listen to audiobooks.
Jan 21, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Playback of audio files does not resume where I left off when powering back on
I have an e260. I use it for audiobooks a lot. I just press pause (centre top of the dial), and the track will resume from there next time (unless I go back to the main menu for radio of course.)
Aug 16, 2008 | SanDisk Sansa e250 MP3 Player
Sansa m250 doesn't continue playing from the same spot after power up
This player will only recognize Audible audiobook files
There is not a fix for the pause/resume issue - it is a major problem for just about every mp3 player that claims audiobook compatibility
Here are some help files:
1) Adding audible books to your MP3 player using Audible Manager (Windows XP)
Windows -
2) Adding books from an online library to your computer using Audible Manager (Windows XP)
Windows -
3) Adding your MP3 player as a mobile device in Audible Manager (Windows XP)
Windows -
4) Deleting an audible book in your MP3 player using Audible Manager (Windows XP)
Windows -
5) Deleting a book from your library using Audible Manager (Windows XP)
Windows -
6) Purchasing an audible book from (Windows XP)
Windows -
May 13, 2008 | SanDisk Sansa m250 MP3 Player
I can't pause a book
Have you tried reformatting it?
that might help as it could be a once off.
God Bless
Mar 11, 2008 | SanDisk Sansa m240 MP3 Player
Taking books I down loaded at the library off
It depends on the agreement you have with the library, most in the country allow 3 downloads before it quits, to avoid people passing them around for free. Overdrive is the choice of most libraries now and they all have DRM type of capabilities. The player will play only what it is allowed to by the file.
Oct 17, 2007 | SanDisk Sansa m240 MP3 Player
Synchronize my m240
The "please synchronize" error refers to the license for the library audio book you have on your device.
You will need to contact the content providers to troubleshoot the license issue.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa m240 MP3 Player
"Synchronize to continue your subscription"
To get rid of that message, you need to connect your Sansa to your computer and open the Rhapsody software to "deauthorize" your Sansa (assuming that you're not going to be using the Rhapsody service). The following URL gives you two options on how to deauthorize your device (look at the bottom section of the page):
Jun 29, 2007 | SanDisk Sansa E280 MP3 Player
Problem synching Sansa m240
Go to my computer and open it from there hopefully you can delete the songs there.
Jul 17, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
