Question about Sony KV-27S35 27" TV
Vertical problem After connecting a Digital Box to our Sony TV and messing with the Remote control, the vertical screen is now jumping up and down. This does not have a button or anything on the menu where you can adjust it or tilt it? Does this mean I now have to have a service man come look at it? Thank you,
  • 975 Answers
IT COULD BE ADJUSTED from the inside , if your handy and good W/ tools you could fix it , if not , call the service man , thanks AJ
Posted on May 19, 2008
Black vertical line down Sony TV screen
that isa capacitor at vertical area mostiy 1000 uf to 22000 /35volts
Sep 03, 2014 | Televison & Video
Picture keeps jumping horizontally and a little vertically cannot find any horizontal or vertical adjustment on t.v. or remote
it is most likely a transceiver error try checking all the connections cable box dvd so on if you have it set to hd it might be an auto picture feature messing with it even though it is not needed checking those too would be thorough
Apr 25, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
Feb 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony WEGA has multicolered vertical lines
OK, much as I have reservations, let's try service mode. To enter service mode, you MUST have the original Sony remote. You need to press these buttons in order, with the TV off. You have about 2 or 3 seconds to complete the series of buttons. Press:
#5 (the 5 on the number keypad)
Vol + (volume up)
Then, after the screen is lit, press the "jump" carefully 3 times. If the word "penle appears in the upper left corner, the optical block is OK and it's probably a Q-box problem. It COULD also be the LVDS cable that sends the signal to the optical block. If you press anything else, IMMEDIATELY TURN THE TV OFF AND START AGAIN. The TV should reset to the original values.
Oct 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand wega KDF-E50A10
unfortunately the B Box assembly needs to be changed in these and price of the part alone is more than half the cost of a new tv
Apr 10, 2008 | Sony KDF-E55A20 55 in. LCD Television
Black Screen with vertical lines down the side?
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
I have trinitron Sony Television.. i got some problem with my TV, the Vertical screen size gone out of focus... I want to know about remote control Commander Codes from which i can resolve my problem and...
I think what your asking is for an on screen service menu?? That wont fix your problem. It sounds like you have a vertical height problem where the screen doesnt fill the entire screen with the Picture. The adjustments wont go out like that for no reason and all by them selfs. The vertical sweep IC went bad and is going to have to be replaced. This is not a job for the end user. You should call an experienced tech to assist you with this repair. Good Luck
Aug 12, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
