FixYa.com
Tags:
Motorola SnapScan
PowerPC disk boot problem
By herself - usenet poster
I'm having problems booting to OpenBSD/powerpc from disk, after installing
it from CD successfully.
Here's what I get (I press RETURN after /bsd):
============= cut =============
0 > boot hd:,ofwboot /bsd load-size=e4cc adler32=e5569bcc
Loading ELF
found OpenBSD DPME partition
I can boot to the 2.9 CD, mount my disk partitions, and all looks fine.
The only issue I had, intermittently, is that the USB bus would sometimes
get "stuck". For example, after booting to the CD, if I press "i" for
install, the key would keep repeating until I reset my USB hub. I would see
"iiiiiiiiiiiiiiiiiiiii" until I powercycled my USB hub. To eliminate this
potential problem, I removed the USB hub and all devices from the iMac,
except the keyboard. That didn't seem to make any difference, as I was still
unable to boot from my disk.
Any ideas?
Thanks,
David
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Bray
Bray - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The pdisk(HFS/DPME) output would be useful as well as the
disklabel output.
When booted from the CD, verify that the kernel is present in the
wd0a partition
There is a problem with the usb driver with key repeat of the very first key
pressed on some systems. it can can be avoided by pressing a non-repeating
key first, such as the shift key, or "fixed" by unplugging the mouse and
plugging it back in.
Dale Rahn                               d @prairieinet.net
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
Dale,
First, thanks for the key repeat tip.
Second, the kernel was NOT on my disk!! I copied /bsd from the CD to wd0a.
Rebooted, but still no luck.
Third, I created a network, and got the following information: pdisk,
disklabel, dmesg.
Let me know if there's anything else you need.
Thanks,
David
pdisk:
Partition map (with 512 byte blocks) on '/dev/wd0c'
 #:                type name              length   base     ( size )
 1: Apple_partition_map Apple                 63 @ 1
 2:    Apple_Driver_ATA*Macintosh             54 @ 64
 3:    Apple_Driver_ATA*Macintosh             74 @ 118
 4:       Apple_Patches Patch Partition      512 @ 192
 5:           Apple_HFS untitled        33888544 @ 704      ( 16.2G)
 6:             OpenBSD OpenBSD          6189830 @ 33889248 (  3.0G)
 7:          Apple_Free Extra                 10 @ 40079078
Device block size=512, Number of Blocks=40079087 (19.1G)
DeviceType=0x0, DeviceId=0x0
Drivers-
1: @ 64 for 20, type=0x701
2: @ 118 for 33, type=0xf8ff
disklabel:
# /dev/rwd0c:
type: ESDI
disk: ESDI/IDE disk
label: WDC WD205AA
flags:
bytes/sector: 512
sectors/track: 63
tracks/cylinder: 16
sectors/cylinder: 1008
cylinders: 16383
total sectors: 40079088
rpm: 3600
interleave: 1
trackskew: 0
cylinderskew: 0
headswitch: 0           # microseconds
track-to-track seek: 0  # microseconds
drivedata: 0
16 partitions:
#        size   offset    fstype   [fsize bsize   cpg]
  a:   261792 33889248    4.2BSD     1024  8192    16   # (Cyl. 33620*-
33879)
  b:   262080 34151040      swap                        # (Cyl. 33880 -
34139)
  c: 40079088        0    unused        0     0         # (Cyl.    0 -
39760)
  d:   262080 34413120    4.2BSD     1024  8192    16   # (Cyl. 34140 -
34399)
  e:   262080 34675200    4.2BSD     1024  8192    16   # (Cyl. 34400 -
34659)
  f:  3145968 34937280    4.2BSD     1024  8192    16   # (Cyl. 34660 -
37780)
  g:  1995840 38083248    4.2BSD     1024  8192    16   # (Cyl. 37781 -
39760)
  i: 33888544      704       HFS                        # (Cyl.    0*-
33620*)
dmesg:
console out [ATY,RagePro_C]console in [keyboard] USB
: memaddr 81000000 size 1000000, : consaddr 81000000, : ioaddr 80881000,
size 1000: memtag 9000, iotag 9000: cons_width 1024 cons_linebytes 1024
cons_height 768
Copyright (c) 1982, 1986, 1989, 1991, 1993
        The Regents of the University of California.  All rights reserved.
Copyright (c) 1995-2001 OpenBSD. All rights reserved.
http://www.OpenBSD.org
OpenBSD 2.9 (RAMDISK) #57: Sat Apr 28 14:45:29 MDT 2001
    dera @powerpc.openbsd.org:/usr/src/­sys/arch/powerpc/compile/RAMDI­SK
real mem = 167772160
avail mem = 142794752
using 2048 buffers containing 8388608 bytes of memory
mainbus0 (root)
cpu0 at mainbus0:
Can you Help with these Scanners problems?
Scanners
scanjet 4050
can not install software from... Answer This...
Scanners
driver for umax scanner 4500
i can't find driver for umax... Answer This...
Scanners
help
do you have scanner codes Answer This...
Scanners
canon Scanner canon F914900
i need driver of canon Scanner... Answer This...
Scanners
PILOTE POUR SCANNER CANON
Bonjour Je souhaite recevoir le... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
