Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Water Dispenser is slow
Hi we have a Kenmore Elite 73600 and the water comes out the door dispenser slower than I think it should be since it was new. I opened the saddle clamp valve more to see if it would help. It is still under warranty but I am hesitant to contact if it is something I can do with little effort. Does anyone know anything about any problems with the water flow. By the way the filter is not ready to be changed yet.
  • harveyd3 Jun 25, 2008
    Yes you were able to help!! Thank you very much. I tried a few other things first like changing the saddle clamp and putting a 1/4" hole in the copper line but no improvement. Changing the $47 filter fixed it right up and to think it was only 6 months old!!! Thanks again for your help, YOU are the GURU..
  • 958 Answers
If you are saying that the filter is not ready to be changed yet because its not yet six months, you can be wrong. it is just a suggested length of time to change a filter but it is still dependent on the water flowing to the filter. if the filter is not that expensive then you can try replacing it or if you can monitor the pressure of the water coming to the ref then that would be a good solution. you can start fro there. if there is good pressure, there is a big chance that you have a bad filter. if the pressure is low, then there is your answer. i hope i was able to help.
Posted on Jun 21, 2008
Kenmore elite 106.44423603 ice/water dispenser housing - plastic broken off for ice door pin hinge. Any ideas for a fix?
Hi and thanks for using fixya!
There is actually a "kit" that replaces the hinge, housing for the hinge, dispenser door and bracket. Just be sure when you're taking everything apart you pay special attention to how it goes back together. Kit comes with metal bracket that will replace old housing. Now that I think about it the kit comes with instructions! Kit pt# 8201756 and you can purchase it here. Appliance Parts
Feb 04, 2015 | Kenmore Refrigerators
Water dispenser does not work
Most likely you need a new water valve or water switch. If there is a click when you push a glass against the water dispenser, that is the solenoid opening. If no click it might need replacing. On mine, the water came out slower and slower; replacing the water inlet valve on the back near the bottom fixed it.
Nov 19, 2013 | Kenmore Refrigerators
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite HE3 t and latley after it's
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 04, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Hi i have a kenmore model #58585892.the problem:
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. If water does come out-
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
Jul 03, 2009 | Kenmore Refrigerators
Water Dispenser Temperature not acceptable
This is a brand new refrigerator - I cannot solve the problem and I am returning the refrigerator to the dealer. Thank you, but I am not paying $ to fix a new refrigerator. I have tried everything.
Feb 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Water Despenser
Water inlet valve at back of unit may be partially clogged, no repairs on this part, unless it comes apart and has a stainless steel wire mesh strainer that can be cleaned ( not likely), only replacement. BpB
Aug 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
468 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
