Question about LG LD65EL Dehumidifier
LG Dehumidifier overflows when attachment tube/hose attached
When we use the dehumidifier w/o the hose, we have no problem. When we use the attachment and the hose, it seems to overflow and not drain 100% into the hose. Any ideas what the problem is?
  • 1 more comment
  • Anonymous Aug 02, 2008
    Me, too. It's a mystery to install. The instructions tell you to remove the plastic circle covering the drain hole in back of th unit. However, when you try to install the supplied drain adapter it doesn't fit securely.
  • Anonymous Aug 13, 2008
    I have the same issue. It seems that the connect from the actual machine to the white plastic hose connector is very poor. Still looking for a solution...
  • Anonymous Mar 15, 2014
    Unit has drain hose to sewer line. It's used for under-house dehumidification.
  • After 1 year of wondering why the LG instruction manual said no more than shove the white hose connector piece into the rear of the unit until secure, and relying on 'hit or miss' that the drain hose would actually work, (rather than filling up the bucket), I have finally found the solution. Ironically, it came while I was on my knees getting serial number from behind the bucket before they would try to help me by phone. There I saw it! The black interior drain piece inside the unit (top right when you remove the bucket) that the white house connector must be secured over. (Nothing in the manual ever told me to look for this.) As for securing the unit in the back--under the big vertical flap (which must point up and remain outside the unit), there is a smaller flap or triangular piece. They say that should be inside the unit, which it doesn't seem to go, because it is parallel to the large vertical flap), but if you push hard enough it does click onto the unit, while allowing the large while flap to remain outside (with the arrow pointing up), making the entire piece secure. Check once more to see if the white hose connector piece is secured over the interior drain piece (a black plastic elbow piece, on the top inside right where you remove the bucket, as I've said), and you'll be good to go! LG should be ashamed of their manual writing on this and the time I wasted getting my two units to work. However, at least these units are not fatally flawed as I was beginning to think.
Posted on Aug 16, 2008
    Problem Solver:
The hose adapter is difficult too install properly. Be sure that the inlet of the adapter is in position. The adapter will then latch at the back of the unit to prevent it from falling out of position. Also, I had the hose plug with slime one time. Hope this helps.
Posted on Jul 04, 2008
Drains through hose and into bucket
this happens when the drain tube becomes blocked so unit overflows and water falls into bucket and not flows out tube , clean tube and drain port with compressed air (wear eye protection!!!)
Jul 17, 2015 | Keystone KSTAD70B 70 Pints Energy Star...
How is the external tube for draining outside connected to the dehumidifier. Does the tube insert into the right angle nipple, then the threded end conected to a drain hose?
No. The tube inserts straight into the drain hole. Follow the 4 sets below.
1. Connect a garden hose to the threaded drain hose connector.
2. Remove the drain-hole cover.
3. Push hose connector tightly into the drain-hole on Rear Grille.
4. Press the hose down and make sure the "Arrow" on the tab is pointing upward.
NOTE:
The hose attachment will accept a standard garden hose fitting. Do not over tighten the hose when
connecting it to the hose connector, use a rubber washer and tighten by hand firmly without stripping the plastic threads. Be sure the hose lays flat and has no kinks, as it will not drain properly.
Apr 12, 2011 | LG DH404E Dehumidifier
I attached a hose to the drain hose connector. When I insert it into the drain hole it is blocked by the back of the dehumidifier. What iw the correct way to insert? Can you send a better diagram?
The drain hose connector MUST be attached to the unit, before attaching the garden hose.
First, the connector is attached to the unit. Second, the hose is hand tightened to the connector.
If you haven't been doing it in this order, that's the problem.
Mar 13, 2011 | LG LHD459EL Dehumidifier
Hi, I have an LG dehumidifier, model number LHD650EBL. I have a hose attached and inserted directly into a drain in my basement, bypassing the water tray. Problem is, my dehumidifier is saying...
Try to see if operating the float lever by hand can make it turn off the 'bucket full' message. Maybe use a rubber band or tape to keep it in the on position vs. the 'bucket full' off position.
Check to see if the bucket has to be inserted for the unit to operate, and if the bucket has a nozzle to hook a hose up to at the bottom. I have a dehumidifier of a different brand that has this feature that works with the bucket in, but with the drain nozzle on the bucket connected to a plastic tube that leads to a drain for continuous operation without having to empty the bucket.
How is your hose attached to the unit if it isn't attached to the bucket?
Good luck on this repair.
Dec 01, 2010 | LG LHD65EBL Dehumidifier
Can a hose be attached to the LG 45 dehumidifier to allow to drain as it fills?
Yes a hose can be connected to this unit.
1. Remove the drain-hole cover from the back of the unit.
2. Connect a garden hose to the threaded hose connector.
3. Push the hose connector tightly to the drain-hole on the back of the unit
This is explained on the manual on page 12. Hope this helps
Jul 29, 2010 | LG DH404E Dehumidifier
Where to hook up drain hose
On the bucket there should be a cap. If you remove it your hose can attach to it. Run the hose top a drain. If possible, raise the dehumidifier so the water drains properly. From time to time, pour a little bit of bleach into the hose to keep mold away.
Sep 29, 2009 | LG LHD65EBL Dehumidifier
Do i need to disable the collection bucket to attach a drain line to my Matag dehumidifer M7DH45B2a? Or does it keep a full bucket and drain the overflow to the tubing drain?
No just connect the hose and open the hole to the unit to drain and return to usauge. it will fill to the drain opening and drain.
Aug 23, 2009 | Maytag M7DH45B2A Dehumidifier
Have old edison 25 dehumidifier. can i put a tube
look for the drain hole from the collector pan under the tubes that fills the bucket, you could attache a hose there, by removing the bucket out of the way. newer models have a built in one.
Jul 24, 2009 | Dehumidifiers
Water will not go down drain tube
Sounds like you have a clog. Either try plunging the drain in the stationary tub or replace the line from the humidifer.. Just a thought
Jun 10, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
GoldStar DH504EL Dehumidifier
Your dehumidifier should have come with a tube which would allow you to do this very easily. I beleive the part number is 5214A20027B.
Sep 15, 2008 | Goldstar DH504EL Dehumidifier
LG LD65EL Dehumidifier Logo
2,560 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
