Question about Linksys Wireless-G WRT54GS Router (e125894)
I am getting an error reading saying The computer cannot detect my router...
I had a router previously. I changed it today to a new router. The new router is not being detected. I have a WRT54GS ROUTER. I tried to update. It will not detect
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 11, 2010
    What is the brand or model no. of your modem?
    What is the operating system of your computer connected to the WRT54GS?
HOw do u configure isp if u are using dsl?
Posted on May 28, 2008
    Novelist:
  • 144 Answers
Hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- are you using a wired or wireless computer in configuring the router?
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Posted on May 20, 2008
Roblox error
I have the same, it happens to me whenever i get on the ROBLOX site itself. It gives me an error and options to go 'Home' or my Previous Page.
Jan 04, 2014 | roblox.com
I'm trying to reinstall the Dlink via the disk, getting error 112
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
May 20, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Getting error 108 Router not detected. please help
You have to have the computer conected to port #1. Is that how its connected?
May 09, 2009 | D-Link DGL-4500 Wireless Router
Conflict with partner network detected.
Default password is "1234".
You need to set up a subnet that is different than the subnet your vpn is connecting to.
For instance, default on the 334is: 192.168.1.0/24 SO the router will have an IP of 192.168.1.1. Because of the error, the other network has that same subnet (192.168.1.0/24)
And that router probably has the same IP as your router (192.168.1.1)
So one of the networks needs to change. You could just change the IP on one Network to: 192.168.2.0/24 and the IP of the router to 192.168.2.1.
I would change them both though, so this doesnt happen again.
Apr 14, 2009 | Zyxel Prestige 334W Wireless Router...
No wireless detect connection
Hi
Note all changes to be made from wired computer only . Any computer that is phisically connected to the router.
Open the router setup page by typing in your default gateway address( router address) on the web browser
You can get it by
Start -> run -> cmd -> ipconfig
You will see the router setup page opening up
Check what it says . IF on the top it says Internet Status :: Connected then
1. Under wireless you'll see channell and ssid
2. Change channell to 6 or 11 .That gives you the best wireless signal strength . This is the most probable cause .
If you want you can also change the
3. Check your security key
4. And apply changes
5. Now on your wireless laptop go to Control panel ->Network connections -> wireless network connections -> right click -> deleate preffered networks -> refresh netweork list
6. You will find your network there select and connect.
Works great
If Ip status : says not connected
1. restore factory default
2. reconfigure router
3. reconnect
This shoud help and please let me know .
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Router " won't start"
Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard.
I am sorry that we got disconnected in the chat. Please don't hesitate as I will assist you at anytime. I believe their chat session software is not working with the new firefox.
Thanks,
Lee
Jun 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
60 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
