Question about Samsung HCM5525W 55" Rear Projection Television
Samsung HCM5525w peojection tv
Tne red convergence wont adjust.
  • qatarman87 May 24, 2008
    Thanks, do you suggest I replace the whole board and where can I get it? This also happened a few months after I bought this t.v. and it was repaired under warranty.
  • Samsung Master
  • 5,138 Answers
You may have a open resistor on your convergence broad, it also has 3 pico fuses on that broad and 1 of them also could be open.
Posted on May 19, 2008
Got a samsung hcm5525w tv that i cant adjust the blue convegance, the red i can adjust, and using the auto focus only gets trough the green.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 24, 2009 | Samsung HCM5525W 55" Rear Projection...
HCM5525W
Convergence where the tv lines up the three guns (red blue and green). I do believe the board is located next to the power supply board.
Aug 18, 2009 | Samsung HCM5525W 55" Rear Projection...
Blue gun out of focus
There is a manual focus adjustment above and between the red and green gun, located in the front of the TV behind the panel; It is a small black box about 3X3" . This has all three adjustments .
Apr 21, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W 55inch
This is a convergence problem. It happens to all big screen rear projectors. The convergence output ic's need to be replaced. I would let a repair man do this.
Nov 11, 2008 | Samsung HCM5525W 55" Rear Projection...
Perfect focus reads "no sensor data"
hope this helps check out this above links
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Oct 09, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung 55" model hcm5525w
its the convergence problem in your power supply board
thanks.
Oct 05, 2008 | Samsung HCM5525W 55" Rear Projection...
New Convergence board but need help adjusting convergence still
If the new sub board didnt fix the problem you will need a new convergence board as the sub deflection boards with the ICs only powers the convergence board. thats a complete seperate board. Let me know if you need more assistance.
May 22, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Convergence amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
178 people viewed this question
Henry  Thomas
Henry Thomas
