Question about Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Close dvd drive
After opening DVD drive with a pin, now cannot close it
  • Poppy Paul May 19, 2008
    I cannot physically push the drive back in. Something seems to be blocking its return. It is on a Dell laptop. thx
    How do I remove the TSST burner from the Inspiron laptp?
    President:
  • 2,712 Answers
Try pushing it in with gentle but firm pressure. After some distance, it should automatically go in, but at times you may have to push it all the way in.
As Benimur suggested, this could be a problem with the belt-gear assembly/motor, It shouldn't affect the working of the player itself, except for the inconvenience of opening/closing the tray.
If you find this inconvenience unbearable, then you will have to get the device repaired by a competent technician, or replace the player (whichever works out cheaper for you)..
Posted on May 19, 2008
    Brigadier General:
  • 6,966 Answers
Most DVD/CD drive are belt engaged driven by a small motor. If the tray is not sliding in and out by itself, it is highly probable that the belt is cut and therefore of course would require replacement. In some instances, it could be the small motor itself or the servo electronics that control it. There are also known instances when the tray is misaligned or the plastic rail/gear underneath have been worn out.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 1 more comment
  • Louie  Role
    Louie Role May 19, 2008
    Hi again,
    Here is the link for a do-it-yourself repair on CD ROM drives. This is a posting of Luisa_K on a similar problem.
  • Louie  Role
    Hi XX,
    with the indulgence of XX....
    Copy that the DVD drive is in a Dell Laptop. Often they can be removed by removing a single locking screw underneath the laptop and the entire DVD drive can be made to slide out. In certain models, the keyboard must be removed to access this screw and or a locking bar or retainer clip.
    Since you have not posted the model of the laptop, pls try to go to the manufacturer's website. I was made to understand that Dell has a comprehensive service manuals available online here. More specific instructions would be available to you then.
    Cheers.
  • Louie  Role
    sorry gentlemen for the XX, links to your names did not get through. my apologies again.
Cd driver not opening
Open a paper clip and see if you can find a tiny hole in the front of the cd drive. Push the sraightened out paper clip into the hole and the drive should open without power on the computer. The hole on my dvd plyer is just above the switch which opens and closes the dvd drive. If the paper clip is too big you may have to go to a pc shop and buy a pin which comes with most new dvd players. If the owner of the shop is a nice person they may give you a pin and explain more.
Jan 18, 2013 | Gateway Fx Computers & Internet
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
How to open and close dvd drive
If your DVD Rom don't open just take a thin pin and u can see a small hole on the Front of your DVD Rom just put that pin in that hole and press it for 2 Sec then your Drive will open then you can Repair your DVD Drive also also
Aug 11, 2010 | Computers & Internet
Cd dvd door wont open.i push the button to put in cd and nothing happens.i do see a little cd on screen ,then it goes away.
On the front of most CD or DVD drives there is a small pin hole that you can use to open the drive if it gets stuck. Grab yourself a strong paper clip, straighten one end, insert the straight bit into the hole and push firmly once you feel some resistance.
This will partly open the drive tray to either allow you to remove a cd or insert a new cd or dvd.
Question, Is there a light lit on the front of the drive when you are:
a. trying to eject (instead of using the front button on the drive try using the "Right Click and then Eject" option when selecting the dvd drive in My Computer), If not the drive may be stuffed (broken) or perhaps the 4 pin power connection lead at the rear of the dvd drive has fallen out.
b. is the drive tray sticky when opening or closing? (get a new drive...very easy and very cheap to buy and replace)
Good luck,
Steve (Melbourne,Australia)
May 14, 2010 | E-Machines eMachines Desktop PC
DVD drive doesn't open. DVD is inside.
Switch off the pc. Look closely on the CD tray face plate. You will see a small pin hole. Insert a needle or pin through it and press. The tray will open.
Feb 08, 2010 | LG (GDR8163BB) (gdr8163bb 10pk) Internal...
Cd/dvd drive doesn't work. Won't open with eject button, How can I determine if it is a driver or hardware problem?
Look at the drive there should be a tiny pin hole near the eject button, insert a needle (safety pin, sewing, etc.) into the pin hole and push this opens the drive.
You can also try opening my computer and right clicking the DVD drive and select eject. After you do this close the drive and try the button again it may just be stuck if it still won't eject you can try and pop off the front of the drive (very simple it locks back on easily) and find the place where the button connects to the drive to eject and push it, If it still won't open it is your hardware.
Jan 18, 2010 | Dell (3410160) Plug-In Module DVD Drive
DVD Drive door stays open
>One solution is to TAKE A SMALL PIN AND RESET YOUR DRIVE BY POKING THE PIN INTO THE HOLE BELOW THE DOOR..
If this doesnt solve....
You need to necessarily replace the drive..
Jul 07, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
DVD drive
Good day!
Let's try to open your dvd manually. Look at your dvd drive you will find a small hole just beside the push botton, find a long pin push that pin side the hole, it will open you dvd. Push the dvd botton and try to open it again.
Thanks.
Nov 01, 2008 | LG Computers & Internet
Dvd player will not open
look at the bottom of the unit and see if it has a slot to put in a pin and manually open the drive, most of them have some way to do this look for a slot or pin hole to push the release, sometimes they do this because someone pushes the drawer closed instead of using the button or remote, you will have to open it to reset it if that is the case you might have to easily force it open.
Dec 24, 2007 | Televison & Video
DVD Drive won't stay closed
i would sugest getting it repaired if it's in warrenty if not then get a new one the prices are low enough for replacement drive. good luck on this one
Apr 18, 2007 | Sun X6168A Internal DVD Drive
Dell (0F027) CD-RW/DVD-ROM (Combo) Burner Logo
66 people viewed this question
Alun Cox
