Question about Canon BubbleJet i560 InkJet Printer
Color ink runs out too fast
We are using it in the office, NEVER for color printing, as yet the 4 color cartridges need replacing evry threee months. is there a way to avoid it? My wife uses our i560 soley in greyscale mode. We do not use the color setting. However, the color ink cartridges continue to run our. The only cause I can think of is that the printer cleans the heads and uses up the ink. Can this be the cause? Also, does canon make a printer that uses only black ink? The color function is a waste of money for us.
  • wtgodfrey May 19, 2008
    My wife uses our i560 soley in greyscale mode. We do not use the color setting. However, the color ink cartridges continue to run out. The only cause I can think of is that the printer cleans the heads and uses up the ink. Can this be the cause? Also, does Canon (or anyone else) make a printer that uses only black ink? The color function is a waste of money for us.
  • 2,098 Answers
See this link. Type "print using black ink" in the Search box and click the Search button. Select the appropriate option for your computer's OS. Note that you can only do this using plain paper. (I think the printer will still use a little color ink when doing print head cleanings. If you leave the printer powered on all the time, this will reduce the number of print head cleanings.)
Posted on May 19, 2008
Why is my hp officejet 6110 printing everything green
You didn't use the HP printer cartridges? I know they are expensive. but the quality is worth it . I trust not a cheaper ink in a quality printer. You may need to check this HP url
Printer Prints Blank Page or Does Not Print Black or Color Ink for the HP...
When you get to Solution four: Use an automated tool to clean the printhead a helpful tip is to repeat the printhead cleaning up to 4 times .
Jan 17, 2015 | HP OfficeJet 6110 All-In-One InkJet...
I have an all-in-one Kodak ESP 3250 printer. Bought it 4 months ago. I'm interested in printing only in black, but now the color cartridge has emptied and it won't let me print with the black cartridge...
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
Install the color a new cartridge, avoid damage to the print head.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
I replaced my black ink cartridge and the printer will not print. I tried shaking the new cartridge. I purchased an Office Depot cartridge #TO529
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any ink-jet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
If after that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 12, 2010 | Dell Inkjet 720 Printer
New HP F4400 going through ink too fast
It depends what type of things you are printing. If you are printing text, you should be able to print more pages. If you are printing photos, you are using more ink per page. If you use more of one color, you may also run out quicker. You didn't say if you were running out of ink in the black or the color or both cartridges. The black cartridge is rated at 200 pages and the color cartridge is rated at 150 pages. This is based on printing pages that may differ drastically from what you actually print. Here's a web link that explains this in more detail.
http://www.hp.com/pageyield/articles/us/en/IsoInkjetYield.html
Next time you buy a printer, spend a little more and find a printer that has a larger cartridge (check the number of ml (milliliters) in the cartridge). These printers cost a bit more but you will save on the cost of the ink. Cartridges all cost roughly the same regardless of how much ink they have. You can also look at websites that rate each printer cost per black and white and color pages.
Hope this helps. Good luck!
Mar 10, 2010 | HP F4480 All-In-One Printer
The ink cartridges need to be replaced very often epson 810
You can try to change your print quality to a lower setting. This saves a lot on toner. If you are not printing for anything super important you can set some printers to "fast draft" or "draft" quality and that saves a ton. I personally dont usually need to print anything of high quality so I went to my local "Everything" store(not sure if I should use company names) and bought an HP, the cheapest color printer they had which was $30.00 The black and color cartridges together cost about the same as the printer. But I use the lowest setting which is the "fast draft" setting and set it to print in black ink only, and only change that when I NEED something in color and it uses very little and prints very fast.
Aug 10, 2009 | Epson Stylus Photo 810 InkJet Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Lexmark x 3650 change ink cartridge but it still gives a message(
Hi Glesam,
The X3650 uses the No. 37 tri-color cartridge, i.e. 3 colors in 1 cartridge. Unfortunately, when one color runs out, the cartridge has to be replaced. When you change printer, you might want to consider a printer that uses at least 4 separate ink cartridges (black, cyan, magenta, yellow). This way you need to replace only the cartridge that runs out.
Rgds
S88
Dec 22, 2008 | Canon MX300 Office All-In-One Printer
well..only way to do this, is to set your printing preferences, from the applications you use, for black or grey scale printing only. That should remove any signal to color printers to use that cartridge.
be aware, that print cartridges that sit idle, can clog too, so when you do need them, they MAY not be accessible for your needs.
Apr 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
PRINT IN BLACK WITH COLOR CARTRIDGE?
Yes, you can print out in black from a color cartridge, however it is not advised as you will run out of colored ink twice as fast as it combines all the colors to get black.However it works great when your in a pinch and need black ink.
Just go to your printer properties when you print and the option will be in there someware.
Dec 26, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon BubbleJet i560 InkJet Printer Logo
165 people viewed this question
old marine
old marine
