Question about Microsoft Xbox 360 Console
Xbox 360 y will my xbox 360 not go on line now 4
  • wardog67 May 19, 2008
    i do plz need holp now
    Problem Solver:
  • 5 Answers
Has it had the drive flashed if it has your box is baned from XBOX Live. you will have to get anothe xbox to go online...sorry
Posted on May 19, 2008
Port 88 UDP problem
1) You have to enter UDP and TCP on seperate lines with same port numbers in each line respectively. So you will have four lines, UDP 88, UDP 3074, TCP 88 and TCP 3074. Also, make sure you have your 360's IP entered. You can find that in the 360 network info.
2) Also, place your 360's IP in the DMZ. That should help.
3) For testing, turn off the routers Firewall. It will make it easier to figure out what is going on.
Nov 17, 2012 | Gateway Belkin F5D7230-4 802.11g Wireless...
How do i reactivate the wireless controller to my xbox 360
How to Configure an Xbox Controller Fotolia.com"> configure-xbox-controller-800x800.jpg Configure you Xbox controller.
The Xbox 360 utilizes two types of controllers: wired and wireless. Like most operations on a video game console, configuring a controller requires little effort. You can either plug the controller into a port on the Xbox 360, or sync a wireless controller using the console's built-in controls.
Difficulty:Easy Instructions
  1. Wired
    • 1 Connect the controller's cable to the in-line release cord. This cord prevents you from accidentally pulling the Xbox 360 along with your controller during game play.
    • 2 Insert the in-line release cord's USB plug into the USB port on the front of the console.
    • 3 Turn on the console to activate the controller automatically.
    Wireless
    • 1 Insert batteries in your wireless controller, if necessary.
    • 2 Hold down the "Guide" button on the controller.
    • 3 Push the Xbox 360's "Connect" button, located on the front of the console.
    • 4 Push the controller's "Connect" button to sync it with the Xbox 360.
Read more: How to Configure an Xbox Controller ' eHow.com http://www.ehow.com/how_7780486_configure-xbox-controller.html#ixzz1PRsAYmUA
here is a video on how to sync your wireless controller to your xbox360 console
http://www.youtube.com/watch?v=GpV-b1de2lM&feature=related
if you think this help please rate me sir thank you so much!!!
Jun 16, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Could you tell me in steps how to conect to xbox live
Step 1 Form your Xbox 360 you need to be connected to the Internet by a straight LAN line or wirelessly. You can test you connection by going to the setting screen on your Xbox 360.
  • Step 2 Once connected to the Internet for your Xbox 360 go to your main account screen and find the tab that says "Join Xbox LIVE" click on that link then follow the simple instructions that the Xbox LIVE will provide. At this point you should have a name in mind for your gamer tag.
  • Step 3 Xbox 360 LIVE has several different options available for memberships. They are a monthly, 3-month and 12-month membership accounts. I would recommend a simple one month account if you just wanted to check out the features offered on XBOX 360 LIVE. If your an avid gamer and love to play games online with friends, the 12-month Gold membership is the way to go.
  • Step 4 Once you've completed the process of joining Xbox 360 LIVE, they will send you a confirmation email confirming your membership. Now you can log on to Xbox 360 LIVE and start doing this like customizing your avatar and playing online multi-player games.
  • May 26, 2010 | Microsoft Xbox 360 Elite Console - Black
    Xbox 360 problem i have lines in the graphics only
    u have a melted graphics chip send to microsoft n tellem u have the 3 rings and theyll fix it
    Jan 30, 2010 | Microsoft Xbox 360 Console
    Games won't read when they are insterted into my xbox 360
    Your DVD-ROM drive2.gif has failed. I had this same issue about a year ago.You will need to call the XBOX support line if your system is still within the manufacturers warranty. (1-800-4MY-XBOX) If they will be doing the repairs you will normally get your system back within 3-4 weeks.
    Oct 01, 2009 | Microsoft Xbox 360 Console
    3 red lights on my xbox 360
    Unfortunately this is a common problem, it means the xbox has failed. Please call Microsoft at 1-800-4-My-Xbox for a free repair.
    Sep 02, 2009 | Microsoft Xbox 360 Console
    Xbox 360 is showing purple lines on tv screen.
    Hi...
    Pull out the video cable from both ends.
    Re-attach and try again
    Let me know
    Jan 18, 2009 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    23 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
