Question about Nokia 7373 Cellular Phone
No Charge, No Power
I tried updating my phone via USB cable at Nokia.com, I have Nokia PC Suite and i was already in the middle of the update and then my computer restarted and my phone displayed a white screen and now my phone doesn't charge or even turn on. Is there any thing that can give my phone life again?????
Please HELP!
I Love this phone
    Sergeant:
  • 282 Answers
Now you need to fullflash the phone, I mean fully reprogram that. But you yourself can't do that without professional tools and cables.For this go to a repair shop. They can do it for you.
Posted on May 19, 2008
My phone nokia asha 308 not conect to my pc via usb cable for internet
U have to download pc suite to access the internet go to nokia site and download or go to www.filehippo.com to download the pc suite
Nov 22, 2012 | Cell Phones
Tip
Nokia Firmware Updates
Hello, this is a tutorial explaining which steps you should follow in order to perform a firmware update or "Flash" on you mobile phone.<br /><br />What you will need to do this Procedure:<br /><br /> <ul> <li>USB data cable</li> <li>Nokia PC Suit</li> <li>Nokia Software updater</li></ul>In this tip the link for both PC suit and Updater will be provider for download.<br /><br /><img src="lock123.jpg" /><br /><br /><span>Step 1:</span><br /><br />You will need to <span>backup</span> all the data on your phone before you start doing anything else. You can either do the backup by following either the steps below:<br /><br /> <ul> <li>If you have a memory card in your phone, you can do the following: Tools&gt;Memory select options&gt;Backup phone memory. Once the backup is complete, remove the memory card from the phone.</li> <li>You will also be able to backup your phone using Nokia PC Suit. Once you have installed it, you will need to connect your Phone to your computer using the USB data cable. Once the phone and the computer is connected, you will have an option to backup the phone data.<br /></li></ul>At the links below, you will be able to download Nokia PC Suit and Nokia Software Updater.<br /><br /><a href="http://europe.nokia.com/support/download-software/nokia-pc-suite/download">Nokia PC Suit</a><br /><a href="http://europe.nokia.com/support/download-software/device-software-update">Nokia Software Updater</a> (To download the correct version for your phone, you will need top select your phone model)<br /><br /><br style="text-decoration: underline;" /><span>Step 2:</span><br style="font-weight: bold;" /><br />Before you start the actual firmware update, you will need to charge your phone, to ensure that the phone will not disconnect during the updating process. If the battery does not have the sufficient charge, the process will not start.<br /><br /><br /><span>Step 3:</span><br /><br />Since Nokia PC suite is already installed, you will now need to install Nokia Software Updater. Once the install is done, you might need to check your Firewall settings to ensure that there will be no data blocked or filtered during this process. Click <a href="http://www.microsoft.com/windowsxp/using/networking/security/winfirewall.mspx">HERE </a>to see how to set firewall settings.<br /><br /><br /><span>Step 4:</span><br /><br />From now on it's really simple, just follow the guide and you'll be fine. The whole updating process takes several minutes to complete, don't try to cancel it in the middle in any case, your risk damaging your phone. You will need your USB cable in this step.<br /><br /><img src="lock123_0.jpg" /><br /><br /><span>Step 5:</span><br /><br />Lastly you will need to restore the backed up data once the update is compete. Again, this can be done in two<br /><br /> <ul> <li>if you used a memory card for backup then you simply go to the <i>Tools</i> - <i>Memory</i> select <i>Options</i> - <i>Restore from card</i>; if you used Nokia PC Suite you have to connect your phone to the pc via <span>USB</span> cable, select Backup and Restore</li></ul>And then you are done.<br /><br />I really hope this can be of help. Please feel free to share your thought and advise.<br /><br />Kind regards<br />Lock123<br /><br /><br />
on Dec 10, 2010 | Cell Phones
Software out of date
update your software via high speed internet.
1.Make sure you have a high speed internet connection with your PC.
2.connect your phone to PC using data cable via pc suite.
3.Download Nokia software updater from nokia.com
4.open nokia software updater and follow the instructions.
5.finish it !
Note:1. phone will restart itself several times while updating .
2.Dont disconnect phone in the middle of the update process.
3.take a backup of the data stored in phone memory because all will be erased.
4.remove sim and memory card while updating !
thanks !
vote me if satisfied with my solution.
Jan 16, 2012 | Nokia 5130 Cellular Phone
How to update software using pc
Use OVI softwARE or upgraind your phone
Jun 29, 2011 | Nokia 3110 Cellular Phone
I am using the n97 and it gets freezed most of the time... now a days it turns off automatically very often... what to do to get rid of this problem???
Dear user,
Please try updating the phone via OVI suite , first connect it to a PC via USB cable, update the OVI suite if necessary and then check for phone updates. it could solve this problem
Jun 22, 2011 | Nokia N97 Cell Phone
How do i renewer my Nokia software
You can update your phone's software or reinstall it by following the steps below.
1.Download Nokia Software Updater from the following link.( http://europe.nokia.com/support/product-support/device-software-update/update-with-pc ).
2.Install it on your computer along with the PC Suite provided with your phone.
3.Connect your phone via USB Cable to the computer in the PC Suite mode.
4.Backup your personal data to the Memory Card or your PC using Nokia PC Suite.
4.Double click and open the Nokia Software Updater (Make sure that the broadband connection is active on your PC)
5.Your phone will be automatically identified by the Nokia Software Updater and will find the available software updates.If there are no new updates available for your phone you can reinstall the software.
6.Click on the start button to proceed.Please don't try to use or disconnect the phone until update is complete and phone is restarted.
7.Disconnect the USB Cable when the update is completed and phone is restarted.You can use the phone as usual.
Jun 21, 2011 | Cell Phones
I want to update my phones software
TO update the phone software you can contact the your mobile care authentic units or one the mobile you go to settings ->phone mgmt->options->software update.
NOTE:you may require internet connectionand data charges may apply
Dec 13, 2010 | Cell Phones
My e65 doesn't want to send or even recieve texts
Try flashing your phone. Install NOKIA PC SUITE and NOKIA SOFTWARE UPDATER (google them and select them from the Nokia websites) on your computer. Then connect your phone via the USB cable. Once the Nokia PC Suite finds and instal your phone, then run the Updater. It should allow you to install a higher version or the same version of your software. If you like to keep your data, you can use the nokia PC Suite to back up your entire phone before running the Software Updater. Afterwards use the same to Restore your Data.
Make sure your phone is fully charged before doing this.
Jun 24, 2009 | Nokia e65 Cellular Phone
Connection 6288 to PC
hey me too hv 6288 and just now i updated wid 6.43 furmware...u just take ur usb cable(DKU-2 or CA53)and update ur latest nokia pc suite in dat there is a option of updating software try from pc suite ur problem will get solved but dont try to update ur phone through nokia website...u will not get success from their.
May 17, 2009 | Nokia 6280 Cellular Phone
Nokia 7373 Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
