Question about Zenith Audio Players & Recorders
Zenith stereophone high fidelity phonegraph model x 930 w wiring problem
The four wires coming out of the needle arm are disconected and i cant fix them plz help
3 Suggested Answers
  • 12 Answers
SOURCE: Need a replacement needle for a Philco turntable
Check for Philco stylus replacement. You may need to find the "Contact Us" tab and request information for your particular model, but if they can't help you, then contact Philco (division of Ford Motor Co.)
Posted on Jun 28, 2009
  • 77932 Answers
SOURCE: Need needle for zenith stereophonic
The best place to get a replacement is from any Radio Shack electronics store. You can also get needles on line.
Posted on Jan 17, 2011
I have a Pioneer PL-740 turntable that works extremely well, except there is zero damping when either lifting or dropping (and I mean dropping) the needle. I know there is generally a hydraulic oil that...
most turntables actually only dampen during automatic play and return (eject) not when manually manipulating the needle. Better turntables will have a counterweight at the back of the arm behind the pivot point, but that is to decrease wear on the vinyl and increase needle life and audio fidelity in the higher end.
Some turntables have a lifter arm that is dampened, but if your player doesn't have such a mechanism, or if it has one and you choose to manually manipulate the needle without it's usage, there is no dampening.
The fix unfortunately is to buy a turntable with a dampened lifter arm, and to use the arm when lifting and lowering the needle.
Mar 23, 2011 | Pioneer Audio Players & Recorders
Need needle for zenith stereophonic high fidelity
Jan 17, 2011 | Audio Players & Recorders
Need a replacement needle for a Philco turntable that has a Diamond needle? The model # is a 1962 Philco Stereophonic High Fidelity model # K-1636X-121
Jun 28, 2009 | Audio Players & Recorders
Cant connect. What type of device is the Motorola h350?
Motorola H350 is a Bluetooth headset device. Free yourself from confining wires and immerse yourself in music with wireless Bluetooth stereo headphones! You can comfortably enjoy your favorite music without messing with annoying wires!
Jun 26, 2009 | Motorola Mobility Bluetooth Hands Free...
Plays records too fast, needle cartridge is loose
Many of these old phonographs play a little too fast. one possible fix is to rig up a dimmer switch into an "extension" cord that you plug this vintage phonograph into. The lower voltage will slow it down and you will be able to adjust the speed.
May 29, 2009 | Zenith ZN110 Remote Control
Goodman heat pump wiring
ok Let me see if this helps if not please comment back with the t-stat model and make as well. The Y terminal on the t-stat needs to be connected to the Y terminal on the heat pump board. If this does'nt fix it your thermostat may have something different going on so please send me the model and make of the t-stat. Also if you know does this unit have outside temperature sensing probes, and or an automatic defrost cycle?
Jul 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Cut wires
Per the KOSS website your KSC 75 stereophone is covered under the Lifetime Warranty Policy. To have your product serviced, please send the stereophone along with $6.00 each ($7.00 Canadian) shipping and handling to the appropriate address for your location. In the United States: Koss Corporation 4129 N. Port Washington Ave. Milwaukee, WI 53212 1-800-USA-KOSS email: In Canada call: 1-800-USA-KOSS email: Outside US and Canada: Contact Koss S.A. for the distributor/repair centre nearest you: ++41-91-641.61.20 email:
Jul 13, 2007 | Koss KSC75 Consumer Headphones
Emerson NR305TT - Replacement Turntable Needles
I have the same model. Though I haven't replaced the needle yet, I was able to remove the broken one. You'll see that the arm has a red plastic attachment. It houses the needle in a very thin strip of something like electrician's tape. There is a very small separation on the front (end of the arm facing you) of the tone arm, where the arm (black plastic) and needle "cartridge" (red plastic) come together. I used a metal nail file and pried them apart very gently. At this point the red plastic "cartridge" with the broken needle was hanging but still connected on either side. The red plastic "cartridge" is made with tiny plastic 'bumps' that pop into indentations built into the black plastic of the arm. Again, using my metal nail file, I simply held the arm and pried the red plastic "cartridge" away from one side. It popped off the other immediately and fell away from the arm. Voila!
Hope this helps!
May 29, 2007 | Emerson NR305TT CD Shelf System
319 people viewed this question
Top Zenith Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
