Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Ultmate Care II won't drain
Washing machine will not finishing draining. It will start and then stop. But the water does not go out. If it is clogged how can i fix it. Washer runs but does not drain water at the end of cycle.
  • Birkheads May 24, 2008
    Same problem here. My wife's bailing water out of it as I type. I guess we'll try looking at the drain hoses first. If the hoses appear to be fine, what do I check next - the drain pump or the lid switch?
  • tomainr579 Jul 02, 2008
    Mine won't drain at all. It fills, agitates and then gets to the drain cycle then stops. It doesn't drain a drop out of the tube. Any suggestions??? Please help. I just put a new drain pump on and am running out of ideas!!
  • 868 Answers
You will have to remove pumps hoses and make sure they are not clogged.
Posted on May 23, 2008
Stops during rinse cycle and won't pump the water out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Sep 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Washing machine stopped working and water will not drain
if washer does not spin then you need to check lid switch. if just not draining but everything else is ok then drain pump is restricted. check for restrictions in drain hose
Jun 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not drain water after washing
it sounds like your lid switch ic either broken at the lid or it is non functional open the lid to manually see if it is broken you schould be able to see it visably on the lid if it is broke your machine will not go into spin and not drain
Nov 24, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not finish draining
i have amagtag neptunetl washingmachine and it won't drain the water all the way out nor will itspin out is computerized.sure could use your help
May 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal De
