Question about Apple iPod MP3 Player
My iPod keeps pausing!!
I would be sitting there walking or driving and all of a sudden my iPod pauses. I know I have all the newest updates for it and I know everything is installed right. Do these iPods have a firmware update so that I can have this problem resolved? Like I know that it has never been dropped at all and was never opened in anyway, so I dont know why its pausing once and a while
  • 1 more comment
  • punky volo
    punky volo May 20, 2008
    vimax
    f.073
  • attaboy1 Aug 06, 2008
    Started having the same problem when I got a new headphone, thought it was the first and got a new philips. it even got wost, I can barely play a song without the ipod pausing four or five times.
    Got back the old ones that came with the ipod and the problem seems to disappear. The problem seems to be the jack plug receptor on the ipod. The standard plugs are slightly loose on it, and it triggers the auto pause mechanism on the ipod when there is slight movement. This could even be as a result of the ipod drive spinning.
  • Frogarg Sep 13, 2008
I got this fix from someone on one of these forums so I can't take the credit. It seems to sort the problem out though. Basically the ipod firmware auto pauses when you take the headphones out. Sometime the jack is so sensitive (especially if you buy new phones), that it thinks that you have removed them when you haven't. There is no way of turning this function off (that I know of). However, if you install Rockbox instead (a different operating system that has loads more functionality) then you can switch this function off, resolving the problem.
The only drawback is that you have to work with Rockbox. I only downloaded it last night but it looks pretty neat, way better than the default ipod one.
To switch it off you go to
Settings > Playback Settings > Pause on Headphone unplug > then there are 3 options to play with.
It's worked for me and stopped the infuriating pausing of tracks sometimes a dozen times per track. Relief!
Posted on Sep 12, 2009
I found that the headphone jack had become worn through heavy usage, so would kick in the sensor which detects the headphones being removed. It does depend which Ipod you have, in my case the 80gb classic has a detached headphone/hold assembly which can be replaced for a fiver from ebay, including some which provide you the tools to prise the case open. Its attached to a separate ribbon cable and is fairly easy to replace. No guarantees but was a cheap foix for me.
Posted on Dec 23, 2009
From the sound of it you had the same problem i did, when you sit you are pushing the jack too far into the socket and the ipod pauses. The solution is going to sound a bit weird but believe me it works. Put a tiny drop of super glue at the top of the phone jack about 0.5 mm. This stops the jack being pushed to far into the hole.
Posted on Dec 08, 2009
  • Apple Master
  • 13,433 Answers
Try a reset and a restore
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
reset on top and restore at the bottom.
Posted on Jun 15, 2008
I have an Ipod touch, and when I press play for a song it goes to pause. Like the play button isn't working. What do I do?
Because it is a touch screen, the play and pause are essentially the same thing. I think a system restore may help you out, check out this walk through. http://www.apple.com/support/ipodtouch/assistant/ipodtouch/
www.whiteboxservice.com
Jun 17, 2010 | Apple iPod touch
CANNOT GET MY IPOD TO TURN OFF
hold down the Play/Pause button. It may not work the first few times you try it, but keep trying that.
If this doesn't work, then let it sit for about 10 minutes without any music playing, and it should turn itself off.
Dec 31, 2009 | Apple iPod MA446LL/A MP3 Player
IPod Touch pauses itself
This can be caused by the audio jack, if it doesn't sit tight anymore, the headphone becomes disconnected for small periods of time causing the iPod to detect the headphone as unplugged, hence it will pause. Try different headphones, especially nickel plated ones and make sure there's a tight fit. If that doesn't help the jack needs replacement. If you're out of warranty you can send it to a third party iPod Repair Service.
Mar 13, 2009 | Apple iPod touch
Pausing
This can be caused by the audio jack, if it doesn't sit tight anymore, the headphone becomes disconnected for small periods of time causing the iPod to detect the headphone as unplugged, hence it will pause. Try different headphones, especially nickel plated ones and make sure there's a tight fit. Also you could have corrupted mp3 files on there, especially if it only pauses on certain songs, delete those songs, restore and transfer again. If that doesn't help the jack needs replacement. If you're out of warranty you can send it to a third party iPod Repair Service.
Dec 28, 2008 | Apple iPod nano
Ipod pauses itself
it will always pause when you plug it into another device. there is nothing wrong with the iPod
Dec 26, 2008 | Apple iPod nano
My ipod won't update or sync and some of the song are on the ipod but wont play some of the time what do i do?
my ipod wont let me copy song ive tries most things. it will not sync as it keeps pausing and i tunes keeps freezing. can anyone help.
thanks emma
Dec 19, 2008 | Apple iPod classic MP3 Player
Random pausing
Hey,
Try to reset your ipod, also try a restore, both explained on this page
reset at the top, and restore in the end.
Thanks,
Ekse
Aug 24, 2008 | Apple iPod nano
Shuffle not working, blinking green-yellow led.
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Jun 25, 2008 | Apple iPod shuffle Second Gen. Silver (1...
My iPod won't go to sleep
try holding down pause and then move the hold switch sraight after. hope i was a help xx
Apr 05, 2008 | Apple iPod nano
Ipod just pauses
This can be caused by the audio jack, if it doesn't sit tight anymore, the headphone becomes disconnected for small periods of time causing the iPod to detect the headphone as unplugged, hence it will pause. If you're out of warranty you can send it to a third party iPod Repair Service.
Mar 10, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Apple iPod MP3 Player Logo
3,361 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
