Question about Sony PlayStation Portable (PSP) Console
BATTERY WILL NOT CHARGE
I CAN TAKE BATTERY OUT OF UNIT AND IT WILL CHARGE IN ANOTHER. ALSO I AM GETTING 5.4V AT TERMINALS NEXT TO CHARGE PORT.
    Sergeant:
    Champion:
  • 427 Answers
The battery is probalby dead, try buying or borrowing a new one.
Posted on May 19, 2008
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
Hi, have a shoprider TE-889XL. Unit has new batteries and has had both the speed and throttle potentiometer replaced over the last 3 years to cure erratic throttle. Now with fully charged batteries it...
On older units this is a fairly common issue with loose, burned contacts at the battery terminal, battery harness plugs and circuit breaker. Check, clean and lube all the power connectors with a petroleum jelly. Don't use WD-40. Then retighten the connectors.
Another issue may be a bad key switch. Intermittent contacts can often be detected by wiggling the key when it starts acting up.
Oct 23, 2013 | Pride New Mobility Victory XL 4 Wheel...
My Nikon S4000 (black) won't charge. I've tried plugging and unplugging the cable in the socket. I've made sure the cable is connected properly into the camera's port. I've tried charging via the computer...
Follow this order:
when plugging in the camera and then plugging into the compuer does the computer recognise it? If not this is either a bad cable, or not an active USB port, or something has gone wrong interanlly with the camera. Internal can be anything from bad voltage chip to bad battery. But some people have put the battery in backwards or with the positive terminal the wrong way. Double check that this has not happened, as anyone could have done it, unless you live alone. Try another computer and see if it recognises that camera if so the cable is good and you can continue to trouble shoot in other areas.
Mar 10, 2011 | Nikon Coolpix S4000 Digital Camera
Ican get my tomtom gps to come on
If your gps does not come on, then it means power is not reaching the unit. The power is mainly obtained from the battery, and if the battery is not charged, then it will not come on. Try to charge the gps device for about 2 hours then try to turn it on. If it does not come on, then it means the battery did not get charged. That can be a problem from either the battery or the charger or the charging port.
First test the battery by fixing it in another gps and charging it for about 2 hours then turn it on. If it powers on the gps, then it means the battery is okay, but if it does not turn it on, then it means the battery is weak and cannot hold a charge and the solution is for you to replace the battery.
Next you test the charger by trying it out on another gps device, if it turns it on, then it means the charger is intact but if it does not turn it on, then the fault is from the charger.
Finally, test the gps itself by trying to charge in by connecting it to the computer using the USB cable, then you turn it on, if it does not come on, then it means there is a problem with the connection port or there is an internal problem or something with the unit.
Hope this helped.
Jan 01, 2011 | Tomtom GPS
Battery won't hold charge
The reason your phone is not holding a charge is simply because there is a problem with the terminal head.
The terminal head is malfunctioning and is not charging the battery.
To fix the terminal head,
  1. After removing your back cover and battery, remove the screws you see.
  2. With the screws removed you can now remove the battery compartment.
  3. With the battery slot removed you have access to the terminal head.
  4. it is the metallic sheets that rests on the head of the battery when inserted into the phone.
  5. Get a pin tip soldering iron and disconnect the terminal head from the green panel you will see,
  6. replace it with a new terminal head.
  7. Reverse the whole procedure for reassembly.
Another fault might be the charger or the charging port,
To test if it is the charger,
Try to use the same charger on another phone to see if it will work,
If it does not work then it is the charger.
To test if it is the charging port,
Test a well tested okay charger on the phone to see if it will work.
If it does not then the problem is the charging port and to change it
you follow the procedure of of changing the terminal but you have to disconnect the screen and the remove the charging port and replace it with another new one.
take care
Jun 19, 2010 | LG VX8350 Cellular Phone
My Garmin Nuvi 750 is not charging or keeping a charge in the car. I can charge it on the computer but when I use it and have it plug in the car it only last one hour and then cuts off saying low battery
Hello there:
This is normally meaning that the batterey may be damaged or the terminals that the battery connects to may need cleaning or damaged so first unplu the unit and open adn remove the battery next get some rubbing alcohol and a q-tip and clean the terminals really good both on the battery and the unit it'self
next inspect the terminals really good and see if they are loose if so you will have to have it serviced
next inspect the plug in on the unit to see if it is loose and not getting a good connection
If every thing seems ok replace the battery and plug in every thing and try it out
and finally check the charger it'self and see if it is in good working order and replace it if it looks worn out or bad ok if you have your warranty you may be able to use it to get it repaired ok
Hope this is very helpful
Best regards michael
Jan 15, 2010 | Garmin nuvi 750 GPS Receiver
VOSTRO 1710 BATTERY WON'T CHARGE
If the battery will not charge, try this:
1.) First, power reset the unit by powering it off, unplugging it from AC power, removing the battery, then push and hold the power button on the unit for about 60 seconds.
2.) Next, plug the AC adapter back in (LEAVE THE BATTERY OUT), power the unit on. Does the unit power on?
If yes, Power the unit off and put the battery back in, let it charge overnight. If, after this the battery will still not charge, you will have to replace the battery. Contact the OEM to ensure you get the correct battery.
If no, remove the AC adapter carefully, look inside the DC port (where the charger plugs in to the laptop) you should see a small silver pin. Is this pin missing or bent? If the pin seems to be in good shape, then most likely you will have to replace the AC adapter. If it IS bent or missing, then you will need to contact a laptop repair center.
Oct 08, 2009 | Dell Vostro 1500 Notebook
NOKIA 5310 not charging? i already replace a new battery and check the power adapter,,(thanks for helping sir brukau747) and test the output voltage of my charger,,and they are all good,.any solution to...
Eventually the problem was internal hardware, the charging terminals has a problem and that's why you getting this error on your unit while you try to charge your cellphone,
You have an alternative to use a desktop charger in able to charge the battery, or you may bring the unit for repair.
Hope this helps
Sep 01, 2009 | Nokia 5310 Cellular Phone
Cannot chage YP-K3 player
The usb message has nothing to do with the ability of the unit to charge. It just means that the port on your computer is recognised as a USB 1.1 port.
It is more likely that the battery no longer holds a charge. The battery can be replaced but it is difficult to open up the unit without damaging the casing. There are instructions on opening up the unit on youtube. Other than buying a faulty unit with a working battery I don't know how to get hold of the batteries. Be careful when replacing the battery. If it is connected the wrong way you will fry your unit.
Feb 03, 2008 | Samsung YP-K3 MP3 Player
My charging port seems to not work
My advise to you is if you have Sandisk Sansa m240 it does not come with a chargeable battery so you cannot charge it,replace it and your problem will go away. I replaced my unit with a rechargeable battery and I have no more battery problems. I charge my batter in a charger when needed.
Nov 20, 2007 | SanDisk Sansa m240 MP3 Player
Sony PlayStation Portable (PSP) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
