Question about LG DLE7177 Dryer
Lg dle7177 electric dryer
My lg dryer stuck on cool only, and it will not get hot
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
The cool light on the lg is on all the time. It is only actually cooling when it is flashing. You might have a blown thermostat. Call a tech and have him/her check it out.
Sgt48
Posted on May 31, 2008
Try your vent if its clocked it wont heat theres a sensor that turns off if it does get hot ive had the problem before or if your vent is to long causes same problem
Posted on May 23, 2008
LG DLE7177 Dryer runs but wont heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jun 13, 2011 | Dryers
Dryer spins but won't heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 19, 2010 | LG DLE7177 Dryer
Cooling light stays on
remover the filter and run it see if that helps or remove the vent from the back
Apr 24, 2010 | LG DLE7177 Dryer
My dryer lg dle 7177 tumbles but does not heat
If you have a gas dryer...
If your dryer is electric..
heatman101
Apr 09, 2010 | LG DLE7177 Dryer
The cooling light is always on, and it takes about 90 minutes to dry a load.
In normal operation as the dryer is drying the "drying" light flashes and the "cooling" light is on steady until the 5 minute cooldown at which time the "drying" light stays on steady and the "cooling" light flashes. click on this lg link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6253
Nov 18, 2009 | LG DLE7177 Dryer
DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
Sep 25, 2009 | LG DLE7177 Dryer
My LG TROMM DLE7177 on heating cycle finish much quicker
First off, unless you are using the manual dry (timed dry) option, the times listed are strickly an estimate. At the begining of a cycle, the dryer has no idea how big a load you have, how wet it is, and how good your vent is. In your situation, I would clean off the two silver colored moisture sensor bars, located just inside the drum, by the right side of the lint filter area. They are curved, about 5 inches long, and about an inch apart. If you use fabric softener sheets, they can aquire a waxy build up, which inhibits them from detecting that the clothes are still too wet.
Aug 27, 2009 | LG DLE7177 Dryer
LG DLE7177 Thermal fuse
Thermo Fuse is normally followed by the power source or on
the circuit board, Follow power source and you will find fuse.
Oct 21, 2008 | LG DLE7177 Dryer
Lg DLE7177 dryer
It means the duct work inside can be reconfigured to go out the back, the bottom or either side with some additional pipes.
Sep 16, 2007 | LG DLE7177 Dryer
LG DLE7177 Dryer Logo
756 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
