Question about Olympus FE-140 Digital Camera
MY FE 140 OLYMPUS DIGITAL CAMERA
THE LENSE IS STUCK.IT DOESN'T GO BACK IN THE OFF POSITION
  • ALFIMAN May 18, 2008
    s.o.s.
  • 20 Answers
Lens will probabaly need to be replaced. Used replacement lenses can usually be found on ebay. Mechanically inclined person can replace them quite easily. Olympus repair shops are usually quite expensive and it's almost better to get new camera rather than have them repair it.
Posted on Jun 15, 2008
Olympus 5020 lens stuck, turns off after power
Please check if the digital camera batteries in it are effective,if the battery have compatibility problem ,no strong enough power or voltage,the refered satuation maybe happen.Change the olympus battery for a new one ,then try again. After use some years ,the olympus battery life usually end.
Jun 02, 2010 | Olympus FE-140 Digital Camera
Stuck lense on olympus FE-350
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries
(obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
May 31, 2010 | Olympus FE-360 Digital Camera
Need a new instruction manual for our Olympus Digital FE 140 camera
Hello. Click the link below to download the 108 page manual for your camera. Save a copy to your computer for future use.
builderdale
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/bman_fe130_e.pdf
Mar 03, 2010 | Olympus FE-140 Digital Camera
My camera is olympus fe-140 so it connect tecnical proplem which says write protect so what can i do
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, write-protecting it. The position nearest the contacts unlocks it.
If that doesn't solve the problem, try a different card.
Feb 02, 2010 | Olympus FE-140 Digital Camera
Need to download olympus fe-140dig.compact camera Service Manual
Well you can download the manual in pdf format from here: http://www.retrevo.com/support/Olympus-FE-140-Digital-Cameras-manual/id/200bh637/t/2/..................................sodeep
Aug 19, 2009 | Cameras
Olympus FE-140 ok except that flash does not work
Make sure you try and reset the camera to the factory default settings. There may be a setting that you are using that has disabled the flash functionality. To reset the camera - have the camera in shooting mode - press the menu button - left arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera will be back in factory settings - see if flash is able to work now.
Dec 28, 2008 | Olympus FE-140 Digital Camera
Olympus FE-190 lense
If the internal lens barrel gets knocked out of alignment it will cause that condition. If the camera senses that the lens is not in the proper position or not moving, it will turn back off rather than cause more damage. Pushing on the lens barrel to try to fix it will usually cause more problems than it already has. It has to be disassembled to be repaired.
at this point you may also want to check on your warranty status.
Aug 05, 2008 | Olympus FE-190 Digital Camera
Olympus Fe-220 Lense.
i dont think so..i think this is a generic problem for the fe210 just like mine. it would not shoot and only black screen in the view finder... my brother in law brought it to a technician and they replaced the lense assembly.
Jul 06, 2008 | Olympus FE-210 Digital Camera
Camera problem =/
In addition to the one year World Wide Warranty,
issued by Olympus Corporation in Japan, the European warranty, issued by Olympus Imaging Europa GmbH, is
valid for two years from the date of purchase, if purchased after 1st April 2004
Oct 06, 2007 | Olympus FE-140 Digital Camera
Broken camera
Oct 03, 2007 | Olympus FE-140 Digital Camera
Olympus FE-140 Digital Camera Logo
83 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
