Question about Dryers
Maytag gas dryer won't maintain heat
I have a Maytag Atlantis gas dryer, model no. MDG6200AWW. When started, it will heat initially but then the heat will turn off. The tumbler works well and the air flow is ok. We have thoroughly cleaned the unit, inside and out.
Any ideas?
Thank you in advance for your thoughts and suggestions!
    President:
  • 2,712 Answers
Hello JessicaB,
It’s most likely due to a bad vent. Specifically, the airflow through the vent is restricted by any number of factors: overly long, kinks, crimps, clogs, too many 90º turns, etc. Here’s a quick and easy way to check it: completely disconnect the vent hose from the back of the dryer and fire up the dryer. If the heat does not turn off, you know the problem is bad airflow through the vent.
HERE are a couple of pics explaining the Dryer Venting Do's and Don'ts
THIS article may be useful as well.
It could also be that
the gas valve coils are not getting voltage, The four components that could break the circuit to the gas valve coils are: timer, hi-limit thermostat, operating thermostat, and thermal fuse. Any one of these can fail open and break the circuit to the valve coils.
I would get a repairman to take a look at these if the airflow was not the problem.
Hope that helps...Thank you for using FixYa!
IrishDruid
PS - If the solution I provided helped you reach a fix in any way, please take a moment to show your gratitude by assigning a Fixya rating, or "Accept" the solution. Thanks.
Posted on May 19, 2008
  • 2,322 Answers
You will find more info by clicking here. Also here there might some helpful info.
Need to relight pilot light on MDG6200AWW gas dryer.
That unit has an electronic ignitor. You should not have to lite the pilot. There is no pilot to lite. If the dryer is taking longer then normal to heat. Check your vent to the outside. If the ignitor is not turning on it could be the ignitor, flame sensor and or thermal fuse. Check D.I.Y. Appliance Repair Troubleshooting to see if there is anything that can help you there.
Mar 28, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
I have a Maytag dryer MDG6200AWW and at first the machine dried the clothes fine but never shut off. The second load got hot but not long enough to dry whole load. The timer does not advance at all. ...
Remove the front panel to get to the gas valve. To remove the panel remove both screws holding the door hinges and the screws on the opposite side from the hinges across the door opening.
Remove the metal bracket holding gas valve coils.
Replace both gas valve coils, part number 279834.
Good luck,
Vlad
First Choice Appliance
Aug 21, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Not heating
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 12, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Ihave a maytag atlantis gas dryer model mdg7400aww that when I first start it up it gets warm but then stops heating? what is the problem
The operator coils get hot and quit on these ,when they get a little age on them, quite difficult to diagnose. If the coil feels hot to the touch after failure then that is a clue. f00c98f.jpg
Mar 05, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer runs but no heat. gas dryer (maytag)
check the ignitor. depending on the model can be from $25- $90.00 This is what heats up when you start the dryer. like a pilot light on a water heater, only it doesn't stay on all the time.
Feb 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
