Question about D-Link Vonage-enabled Wireless Router (VWR-VR)
Not saving my settings
I just changed my wireless router to the d-link vonage enabled router. my problem i'm having is that if i have to recycle my router to reconnect my local network my vonage router always resets it self to factory defaults. i have to always go backin change the password, readd the other computers, reset all ports, etc. how do i get my router to keep my settings even if i have to sometimes reset my router?
  • queenbee6463 May 19, 2008
    Thank you for your quick response. I have only been unplugging my router to recycle it. I guess i must have a faulty router.
    again thanks
  • Anonymous Dec 30, 2008
    I think that these routers have a problem. If they lose power they reset the security settings and password.
    Problem Solver:
  • 11 Answers
Under normal circumstances, you should never have to reset your router. If you have problems, usually you unplug it, wait a few seconds and plug it back in. You DO NOT press the reset button. If you are not pressing the reset button and only unplugging it and still losing your settings, it is a faulty router, exchange, refund is your best option. If you ARE resetting it, then it is doing exactly what it is supposed to do.
Hope this helps.
Posted on May 19, 2008
How to change pin of dlink router permanently?
go to wireless security settings of the router and do it u will be able to change the pin
Mar 13, 2014 | D-Link Vonage-enabled Wireless Router...
Want to set up WEP encryption, but the router doesn't seem to accept it.
You have to use a static IP or PPPoE IP Address in order to enable this WEP function. Use the ASCII settings to enter text. Look at the restrictions noted.
Oct 23, 2012 | D-Link Vonage-enabled Wireless Router...
Hi, how to create a password for my network, i;m using a mac kind regards
This is done by navigating your browser to the router and logging in. I suggest that you go to dlink.com and download the manual. Access is similar to 192.168.0.1 in the ADDRESS BAR, not search...
Here are the highlights of what needs to be set.
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Jan 14, 2011 | D-Link Vonage-enabled Wireless Router...
How can I secure my wireless
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Sep 28, 2010 | D-Link Vonage-enabled Wireless Router...
Vonage router
You simply access your router from any Browser suach as Internet Explorer, Firefox , & so on. You simply type in it address, and password and log on and set it up generally there is a wizard to do so. Go to the web site below and get software and a manual so you can follow that and set your self up. http://www.dlink.com/products/?pid=VWR-VR
Feb 20, 2010 | D-Link Vonage-enabled Wireless Router...
HOW DO I HAVE TO CONNECT THE D-LINK TO VONAGE
1. plug one end of the cable into the vonage phone. 2. Plug the other end of the cable into a numbered port on the router. Any number will do.
Jan 03, 2010 | D-Link Vonage-enabled Wireless Router...
How should the D-link be setup to work with comcast and vonage? After I set vonage or internet do not work. I tried the comcast modem to d-link and d-link to vonage.
If you want to RECEIVE telephone-calls:
COMCAST ADSL/CABLE modem <---> VONAGE <---> wireless-router
Turn each piece off.
Turn on the COMCAST modem, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the VONAGE router, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the D-link router, and wait for its lamps to settle-down to a "steady" pattern.
Restart the computer that is connected to the D-link router,
and you should have Internet access.
Dec 01, 2009 | D-Link Vonage-enabled Wireless Router...
Router does not save settings
try to reset it into factory defaults.
Jul 21, 2009 | D-Link Vonage-enabled Wireless Router...
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
Need to connect directv from hard line to vonage.
I had vonage with dish network and was able to buy a phonex system for wireless connection. Worked great.
Mar 22, 2009 | D-Link Vonage-enabled Wireless Router...
D-Link Vonage-enabled Wireless Router (VWR-VR) Logo
253 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
