Hi, this radio sounds amazing, but the power randomly goes off, and then comes on.
Do you know of this problem?
Any solutions?
Coule be the head unit over heating, which is unlikely with the built in fan, sounds like a low voltage problem to me.
Hi i have the 9855r, and has been working fine over the years but as soon as ive put it into my new car it switches off as soon as i put the volume up and then switches back on, however i dont know if this fault is because of the unit or the amp or something else.
I have that same problem. when i turn the volume up, it shuts off but comes back on right away. the only thing i can think of is i'm not running the constant power directly from the positive terminal on the battery (which is what is recommended). not sure if thats the solution but im gonna try and wire it right anyway...
This unit was working absolutely fine,then all of a sudden it turns off and cant turn back on again until it decides to come back to life for a matter of seconds and even a minute sometimes. Very good unit,yet a very annoying problem.
Can you help?
Thanks,
Paul.
Unit
Unit has been working absolutely fine when all of a sudden it turns itself off and about every 30 seconds to 1 minute its back on. No buttons want to operate when this problem occurs,but is becoming sum what annoying.
Removed radio and checked connections as im an auto electrician,but all ok.
Is it a ribbon fault or what?
Can anyone help?
Thanks,
Paul.
SAME HERE
